587,613 active members*
4,040 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Anywhere to get ladder for Murata Centrum 2000 eproms?
Results 1 to 5 of 5
Hybrid View
    Dec 2013
    7
    I had to replace the pmc-m board on the Fanuc controller for a Murata Centrum 2000 board. Of course the replacement board had the wrong ladder on the 0f1 and 0f2 eproms. Fanuc says they don't carry these and I would have to go through Murata but I thought I might check here first to see if anyone had this particular ladder. I have a copy of Fapt Ladder 1 so I can burn it even if it was just the files themselves.
    Jun 2004
    511
    What happened to the original Eproms, you should be able to swap them onto the replacement board.
    Dec 2013
    7
    Sorry I should have mentioned I tried that but they don't work. The controller just stays on the boot screen. I can wipe the memory and it will boot up but as soon as I put the parameters back in and restart it does the same thing.
    Aug 2018
    14
    Re: Anywhere to get ladder for Murata Centrum 2000 eproms?
    Hi JedgarG
    Sorry for this inconvenience. I am in a trouble and i need your help.
    I have too a Centrum 2000Q but my machine can't to work as normal because it is lost the parameter of the TDC controller block.
    You can give me that parameter?
    It is very necessarry with me.
    Thanks & regard.
    Send eeprom data to my mail: [email protected]. i converter for you
  1. Replies: 7
    Last Post: 11-20-2019, 10:45 PM
  2. Replies: 2
    Last Post: 08-10-2018, 03:46 AM
  3. Wiedemann CENTRUM 2000Q - FANUC 6M Can't zero set.
    By GuntherDeclerck in forum Fanuc
    Last Post: 11-07-2016, 04:00 PM
  4. refreshing eproms?
    By tc429 in forum Fanuc
    Last Post: 11-02-2012, 02:31 PM
  5. KM3P,There are 2 U75 EPROMS, No U76
    By kc8jyr in forum HURCO
    Last Post: 07-15-2011, 04:32 PM
