603,946 active members*
3,215 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Apparent cross-motor stepper feedback in CNC axes.
Results 1 to 5 of 5
    Mar 2007
    37
    I've been reminding myself for at least a year now to try and sort out this quirk of my machine and I finally remembered:
    So I have an old Tripower bridgemill that 99% of the time I use manually, but it's also wired for CNC which is great when I need it. Still in the process of converting to ballscrews instead of acme thread. A thing I noticed more pronounced recently is that if I rotate my X axis crank fast enough, I feel occasional pulses relaying through the Y axis handle. Usually it's not a huge problem and I can generally eliminate it by slowing down my rotations but I've always thought there was probably just a setting or strategic diode I could put in there somewhere and that this would be a good place to ask. I haven't yet found a post describing exactly this problem- I guess I was expecting it to be a bit more common.
    Anyway, thanks for any help!
    -kevin
    Feb 2008
    644
    Re: Apparent cross-motor stepper feedback in CNC axes.
    Quote Originally Posted by salukikev View Post
    -kevin
    What types of drives/motors do you have?
    Cranking servo Axis faster than they can move under machine control could overvoltage the drives
    Mar 2007
    37
    Keling 640 oz in steppers- like these. I use gecko drives in this system too- I think one or two are the 'V' model.
    Your overvoltage theory seems very plausible- can you suggest a way to remedy that?
    Also- I'm sorry, this will be my 3rd attempt today at posting this response. For some reason the forum does not seem to be posting it.
    Dec 2012
    204
    try to power on the drivers and have them disable the outputs. but leave the power on which keeps them in a controlled state.
    This looks like you generate power which gets uncontrolled to the other motor.
    Mar 2007
    2083
    when you hand crank an axis the stepper motor will act as a generator
    The AC currents produced will be rectified by the diodes in the two "H" bridges in the stepper driver
    the resulting DC voltage can power and other stepper driver connected to the same power supply
    Once the voltage generated is high enough for the driver to function
    the other axis stepper drivers will start to pass a holding current through the other stepper motors
    John
    PS
    part of stepper driver showing
    one motor coil connected to one stepper driver H bridge
    ( the 2 points marked VM are the positive bridge rectifier output and AISEN the negative )
    Attachment 425536
    looks very like a transformer secondary connected to a bridge rectifier made of 4 diodes
    Attachment 425540
  1. Need help! Cross table, Stepper motor + ????
    By Vatro in forum Stepper Motors / Drives
    Last Post: 01-23-2017, 09:44 PM
  2. Plasma Tube Cutter Stepper Motor Feedback
    By Quada in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-05-2016, 05:30 PM
  3. MECHATRONIC 4 AXES MICRO STEPPER MOTOR DRIVER
    By shovelhead3d in forum Controller & Computer Solutions
    Last Post: 04-17-2009, 10:19 PM
  4. Apparent issue with SJ200 & Leeson 3ph 2HP motor
    By haysys in forum Phase Converters
    Last Post: 01-14-2008, 01:04 AM
  5. stepper motor feedback question
    By Syp in forum Stepper Motors / Drives
    Last Post: 02-06-2006, 06:36 PM
