588,159 active members*
4,377 visitors online*
Thread: arc filter
    Nov 2009
    82
    arc filter
    I would appreciate an example and explanation of exaclty how the arc filter and tolerances works in mastercam.
    thanks
    Feb 2010
    371
    The arc filter attempts to utilize an arc rather than a series of XY moves. This is controlled by the tolerance. If you have the tolerance set to .002", then if a single arc move would keep the cutter path within .002" of the original path, it is used instead. This can GREATLY reduce the size of the generated G code, as well as give a smoother, non-faceted cut.
  1. Fume filter
    By seen in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-06-2009, 07:42 AM
  2. *NEWBIE* Power Line filter (Transformer vs. Filter)
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 09-26-2009, 02:36 AM
  3. input filter emi/rf
    By EvanVH in forum Phase Converters
    Last Post: 03-16-2009, 11:42 PM
  4. Air filter for controller box
    By cncuser1 in forum CNC Machine Related Electronics
    Last Post: 09-01-2008, 12:07 AM
  5. Filter Question
    By totalfab06 in forum Waterjet General Topics
    Last Post: 03-10-2007, 02:02 AM
