Does anybody has a diagram that shows how to properly wire a Polabs PlasmaSence THC to a Pokeys57cnc Control Board and configure in Mach4?. I've been following the documentation for Mach4 and Polabs to set up my cnc but I haven't been successful. The information there does not mention a connection or a setting that refers to Ark Ok signal and I believe that is the problem with my system. I can make the machine to begin the M3 sequence, reaching the XY coordinate, followed by the touch-off sequence and piercing the material but it stops right there. My only guess is that Arc OK signal not being detected makes the system to time out and stop. I've used the current version of Mach4 as well as some of the newer development versions and use the Diagnostic Tools to monitor Inputs, Outputs and Registers involved in this process and I don't see the Arc Ok signal. I've been thinking that I might have a connection or setting wrong in my set up, I've contacted Polabs as well as Machsupport and opened a few tickets but it take weeks for them to reply and the information provided is not taking me anywhere.
