587,302 active members*
3,318 visitors online*
Results 1 to 7 of 7
    Oct 2015
    Question arc in XYZ at the same time?
    Hi, im wondering if this is even possible.
    Need to make a circle motion in xyz at the same time
    i have a bowl and im gonna mill 3 lubricating grooves.. 360degrees/3
    so the first groove is only in x and z axis and i use g18 so that works well but the other 2 grooves i have to move xyz all at the same time in a circular motion, is that even possible?
    Do i need to manual program like 100 vertexpoints for this to be possible?
    sorry for my bad english
    Using a Mazak VTC 20-B with Mazatrol Mplus
    Feb 2006
    1792
    Re: arc in XYZ at the same time?
    G02/03 is possible only in the three orthogonal planes.
    You may cut the three grooves after rotating the workpiece by 60 deg.
    Jul 2010
    11
    I'm having a hard time visualizing your part. But would helical interpolation work?
    Jun 2015
    119
    You should be able to program that. You can move a G02 or G03 in XYZ simulatenously. For example:
    G20
    G0 G17 G40 G49 G80 G90
    T1 M6
    G0 G90 G54 X1. Y0 S15280 M3
    G43 H1 Z.25
    Z.2
    G1 Z0. F6.2
    G3 Z-1. I-1. J0. F61.1 <-- Cuts a helical motion, moving in XYZ
    G1 Z-.8 F6.2
    G0 Z.25
    M5
    G91 G28 Z0.
    ____________________________
    My blog: http://www.fletch1.com
    Jul 2003
    1220
    Code G49 C120 will rotate the orientation and then run your G18 code you used for the XZ Plane
    Then cancel with G49 and then G49 C240 etc.
    Note this is for a Fagor controller,
    Fanuc G68 does the same.
    Dec 2012
    395
    Do you have a (3D) drawing or an example for what you want to make ?
    Normally you need XYZ coordinates when you only have 3-axis, generated by CAM-software.
    regards,
    Heavy_Metal.
    Feb 2006
    1792
    Quote Originally Posted by Kiwi View Post
    G68 method did not occur to me.
    Thank you.
  1. Replies: 76
    Last Post: 04-24-2014, 01:42 PM
  2. Replies: 0
    Last Post: 04-24-2012, 01:46 PM
  3. long time reader first time poster
    By blu333 in forum MetalWork Discussion
    Last Post: 02-21-2010, 12:30 PM
  4. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-03-2007, 12:18 AM
