603,380 active members*
3,429 visitors online*
Results 1 to 18 of 18
    Oct 2006
    735
    Arch Commands Boss 10 Please help.
    Well I've been running my R2V3 for a while. Most of the playing I've done have been just streight moves or segmented moves to make turns. Of course due to limited memory using arch moves is a good thing to save program space.. but for some reason and I yet to figure out my machine does not seem to do them right.
    In short when cutting the archs the turn ends up streighter then it should. Like the lower right turn on that part should be a circle but it cuts the corrner off in a shallow arc.
    I run the same code in mach on my other mill and it does not apear to cut the arch short.
    Please see the pics below and segment of Gcode I'm trying to run for my part.
    1 pic of the part
    1 pic of the plot of the part from NCPlot back plotter
    and the Gcode.
    Thanks for Any help to understand what is going on.
    'Bridgeport'
    'Cut StockPart no ramps'
    N4G70G75G40G17G90
    N5G0X0.0Y0.0T12M6
    N6S12000M3
    N7G0Z0.7874
    N8G0X0.1250Y1.1050Z0.0500
    N9G1Z-0.0270F5.0
    N10G1Y1.1055F10.0
    N11X0.1244Y1.1173
    N12G3X-0.6200Y1.7752I-0.7092J-0.0524
    N13G3X-1.3644Y1.1173I-0.0352J-0.7103
    N14G1X-1.3650Y1.1055
    N15Y1.1050
    N16Y0.5455
    N17Y0.5450
    N18X-1.3647Y0.5365
    N19G3X-0.6200Y-0.1252I0.7095J0.0486
    N20G3X0.1247Y0.5365I0.0352J0.7103
    N21G1X0.1250Y0.5450
    N22Y0.5455
    N23Y1.1050
    N24G1Z-0.0540F5.0
    N25G1Y1.1055F10.0
    N26X0.1244Y1.1173
    N27G3X-0.6200Y1.7752I-0.7092J-0.0524
    N28G3X-1.3644Y1.1173I-0.0352J-0.7103
    N29G1X-1.3650Y1.1055
    N30Y1.1050
    N31Y0.5455
    N32Y0.5450
    N33X-1.3647Y0.5365
    N34G3X-0.6200Y-0.1252I0.7095J0.0486
    N35G3X0.1247Y0.5365I0.0352J0.7103
    N36G1X0.1250Y0.5450
    N37Y0.5455
    N38Y1.1050
    N39G1Z-0.0810F5.0
    N40G1Y1.1055F10.0
    N41X0.1244Y1.1173
    N42G3X-0.6200Y1.7752I-0.7092J-0.0524
    N43G3X-1.3644Y1.1173I-0.0352J-0.7103
    N44G1X-1.3650Y1.1055
    N45Y1.1050
    N46Y0.5455
    N47Y0.5450
    N48X-1.3647Y0.5365
    N49G3X-0.6200Y-0.1252I0.7095J0.0486
    N50G3X0.1247Y0.5365I0.0352J0.7103
    N51G1X0.1250Y0.5450
    N52Y0.5455
    N53Y1.1050
    N54G1Z-0.1080F5.0
    N55G1Y1.1055F10.0
    N56X0.1244Y1.1173
    N57G3X-0.6200Y1.7752I-0.7092J-0.0524
    N58G3X-1.3644Y1.1173I-0.0352J-0.7103
    N59G1X-1.3650Y1.1055
    N60Y1.1050
    N61Y0.5455
    N62Y0.5450
    N63X-1.3647Y0.5365
    N64G3X-0.6200Y-0.1252I0.7095J0.0486
    N65G3X0.1247Y0.5365I0.0352J0.7103
    N66G1X0.1250Y0.5450
    N67Y0.5455
    N68Y1.1050
    N69G1Z-0.1350F5.0
    N70G1Y1.1055F10.0
    N71X0.1244Y1.1173
    N72G3X-0.6200Y1.7752I-0.7092J-0.0524
    N73G3X-1.3644Y1.1173I-0.0352J-0.7103
    N74G1X-1.3650Y1.1055
    N75Y1.1050
    N76Y0.5455
    N77Y0.5450
    N78X-1.3647Y0.5365
    N79G3X-0.6200Y-0.1252I0.7095J0.0486
    N80G3X0.1247Y0.5365I0.0352J0.7103
    N81G1X0.1250Y0.5450
    N82Y0.5455
    N83Y1.1050
    N84G0Z0.0500
    N85G0Z0.7874
    N86G0X0.0000Y0.0000
    N87G0X0.0Y0.0M25
    N88M02
    Jul 2005
    409
    Arch commands
    Bob,
    I have a boss 8,
    I think your trouble is due to the bottom arcs coming in towards the center kind of like a rounded W (exagerated I know)What do you use for cad/cam software? If you are using Bobcad I have a post for that at home, I could send you a re-posted file tomorrow.
    I know the boss controls will accept radius command too. That saves a bit of precious space.You could try that. I think with the radius command you can do a 180 degree arc but I will check that when I get home.
    Is the geometry supposed to be continuous arcs? If so there is a problem there.I back plotted the cam file to bobcad and the arcs have different center points.
    Hope that helps
    cutmore
    Oct 2006
    735
    The Gcode produced from a post processor built up for Vcarve to make files for the bridgeport. I've played with the different parts of the post (that I understand) to get it working as good as it does now. But comming here because I'm still missing something but can't really blame vcarve or anything.
    b.
    Oct 2006
    735
    Just confused seeing when I open that Gcode in something like the NCPlot back plotter (like in the picture) the part paths look ok. If I output using the Mach arc's post the code is the same (with the exception of the header G's) and path looks right.
    so just confused I guess. and figured perhaps I was missing some header g command to put it in the right mode for this or something simple like that.
    b./
    Oct 2006
    735
    For example perhaps I sould be in G74 multi quadrent circle input off rather then G75 circle input on. But don't really know what all that means. And not really clear in the manual but think 75 should be on or default.
    b.
    Jul 2005
    409
    Bob,
    I will check my settings when I get home. I am leaving work for the day.
    Try this file. Z zero to be the top of the material.
    :666
    N2G0G17G30G40
    N3G45G70G72G75
    N4G90G96
    T1M6S3000
    M3
    N6X0.125Y1.105Z0.5
    N7G1X0.125Y1.105Z-0.02 F.5
    N8X0.1244Y1.1173Z-0.02 F10.
    N9G0X0.1244Y1.1173Z-0.02
    N10G3X-0.62Y1.7752Z-0.02R0.7112
    N11G0X-0.62Y1.7752Z-0.02
    N12G3X-1.3644Y1.1173Z-0.02R0.7111
    N13G1X-1.365Y1.1055Z-0.02
    N14X-1.365Y0.5455Z-0.02
    N15X-1.3647Y0.5365Z-0.02
    N16G3X-0.62Y-0.1252Z-0.02R0.7112
    N17X0.1247Y0.5365Z-0.02R0.7112
    N18G1X0.125Y0.545Z-0.02
    N19X0.125Y1.105Z-0.02
    N20G0X0.125Y1.105Z0.5
    I will check back tomorrow,
    Cutmore
    Oct 2006
    735
    Thanks for the Gcode.. I'll give it a try and guess the new G's in your headder will be added to my post processor..
    Thanks!!..
    b.
    Jul 2005
    409
    The G codes in the header I understand are
    G0= rapid, G17= x,y plane, G40= tool radius comp. cancel.
    G70= programming in inch, G75= something with the arcs( I forgot to look in the manual last night,Sorry)
    G90= programming in absolute coordinates.
    I will look up the rest, or if you have the manual you could look them up.
    I know every control can have different interpretations of a Gcode so the Boss8 & 10 could be different but I doubt it.
    Hope that helps,
    Cutmore
    Aug 2005
    197
    G75 I think was is full circle ability. Hum may have to do with end piont tollerance.
    can you post a drawing of your part with dims and origin? Just at a glance somthing looks off in the centers of the arcs to me. May be my eyes who knows
    Jul 2005
    409
    Verfur,
    I saw the same thing, the arc center points are not the same. The geometry from backplotting looks like a rounded w on the bottom.
    We will see how he made out when he comes back.
    Cutmore
    Oct 2006
    735
    The archs are as symetrical as they can be far as I know...
    I could post the vectors drawn..
    The code given above gives an error message on the boss screen after the tool change. I altered it as one of the feed rates was .5 and that. But the error said something that sounded like it didn't understand one of the subscripts (I think it said) of course there isn't enough room on the screen to give a complete sentance error and of course I didn't copy it down.
    Far as the manual goes all the Gcodes in the header look like they would be acceptiable. And the manual does have R commands for circle interpolation.
    If I take my drawing and move it to have the part zero in the lower left corner of the part rather then lower right the squashed parts of the arch move to the other corners of the part.
    Just kinda fustrating seeing the same code runs an arch and path just fine under Mach. so maybe my machine is just showing it's age? I'd hate to think that because otherwise it runs everything else I do as good as I could ask.
    Maybe I'm missing something simple but have checked the programmer manual and stuff and think it should work.
    I agree that the centers of the arcs should be/could be the same since the part is symetric but I'm not seeing the squasing when I view it in the back plotter that I see when the part is run.
    Anywho.
    b.
    Jul 2005
    409
    Bob,
    I just looked at the file I sent and this time I changed the 2 arcs to a single arc. Try this and let me know if this works. If so, then maybe it is something with the original file that the Boss just didn't want to do.
    :667
    G0G17G30G40
    G45G70G72G75
    G90G96
    T1M6
    G0X0.125Y0.6198Z0.5
    G1X0.125Y0.6198Z-0.02 F1.
    X0.125Y1.0302Z-0.02 F10.
    G3X-1.365Y1.0302Z-0.02R0.745
    G1X-1.365Y0.6198Z-0.02
    G3X0.125Y0.6198Z-0.02R0.745
    G0X0.125Y0.6198Z0.5
    Hope this helps,
    Cutmore
    Oct 2006
    735
    I'll for sure try it. Thanks.
    I did look at where my orignal gcodes were placing the arc centers and like some have said they don't look like their placement makes any sense to me. So probably fooling the heck out of the bridgeport to.
    Thanks.
    b.
    Oct 2006
    735
    Also Vetric got back with me on how to update the post processor to do absoloute output for arc centers (which is why the code was not working most likely as some noticed the arc centers are not right)..
    Anyway hopefully that is now all figured out. But I'll keep you posted once I try it to be sure.
    b.
    Oct 2006
    735
    Just to give us all an idea where the old and new arch centers were loacated with the post processor change see the 2 pics..
    The colored circles mark the arc end location and the center.
    I'm sure all can see why the bridgeport was so confused.
    b.
    Oct 2006
    735
    That did it.. Thanks to all that helped..
    Now I have the bridgeport busy kicking out these little things.
    Although I need to figure a better way to hold them down..
    but anyway.
    b.
  17. #17
    Jul 2005
    409
    Bob,
    Glad you got the Bport figured out.
    On how to hold those parts, I use vacuum on some of the jobs I do. You just make a fixture that has a channel (made with a ball nose) a tiny bit inside the part. Place a rubber gasket in the channel. A couple of channels in between the gasket, and connect a refrigeration vacuum pump and you would be amazed at how much hold down you have!
    It is nice for repetitious parts cause you can put locating pins or even mill a pocket the part fits in.
    Cutmore
  18. #18
    Oct 2006
    735
    Ya I have to get on the vac hold down bandwagon. Sooner or later I'll have to get me a vacume setup.
    Actually this piece has a bolt hole in the middle so if I locate that first I can bolt it down and that might also work well.
    b.
  1. G2 and G3 Commands
    By Bohemund in forum G-Code Programing
    Last Post: 05-28-2007, 03:12 PM
  2. Difference between BL and SV commands?
    By Shizzlemah in forum Fadal
    Last Post: 03-23-2007, 02:33 PM
  3. Turbo CNC @ Arch cutting ???
    By Milton in forum OpenSource Software
    Last Post: 08-14-2006, 05:48 PM
  4. Design & Cut Arch
    By krazycnc in forum Uncategorised CAM Discussion
    Last Post: 08-26-2005, 03:06 PM
  5. EMC & the G28/G30 Home commands
    By Javelin276 in forum LinuxCNC (formerly EMC2)
    Last Post: 07-18-2005, 09:13 PM
