I Dont Know If I Understand...
Eduardo,
So -- I think:
You compute the intersection point of the lines perpendicular to the tangents at the two points of interest. Then you compute the distance from that intersection to each of the points to get the two radii.
But now we want to approximate the curve between the two points with a circular arc. Ideally, we would like to minimize the maximum error. Since (in principle), we know nothing about the curve between those points, we don't have much to work with.
There are somethings we can do, though. We can require that the arc goes through both of those points. Since there are an infinity of arcs that do that, it is not a problem. The simple thing to do is to use a straight line, but that misses the point of the exercise.
It is clear that at each point, we must start at the previous point. We must also end at the next point. If we don't do that, we risk having unbounded error accumulation.
So, one approach might be to pick a radius between the two that were calculated. Find the center corresponding to it and draw the arc between the two points at that radius. One could pick the larger radius, the smaller radius, the average radius, the geometric mean radius, or something else.
Assuming that the curve is reasonably well behaved (whatever that means), I would think that the error would be less than the difference between the two radii. Hmmm. Perhaps reasonably well behaved means that the curvature is monotonic between the two points.
Tell me more. For instance, do you have a quick calculation for the center, given the two points and the radius. (Give me a break, please, it's been almost fifty years since I studied plane geometry.)
Thanks,
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
