603,546 active members*
3,081 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Array toolpath
    Oct 2006
    51
    Array toolpath
    This is for Svenakela. I watched a video where you arrayed a toolpath then ran a command to repair group. I have the latest version of Madcam and it doesn't seem to have that command that I can see. Is there a way to accomplish this in the newer version? Thanks
    Mar 2004
    1661
    Re: Array toolpath
    That's because you don't have to repair the group any longer. You can select a tool path, array it and all paths will be in the same path layer automatically.
    I just did it with both a roughing tool path and a pocket operation.
    Oct 2006
    51
    Re: Array toolpath
    Thank you for the quick response. I'll give it a try.
  1. Eagle PCB array?
    By stk2008 in forum PCB milling
    Last Post: 03-21-2011, 07:05 PM
  2. EnRoute Toolpath Array
    By Gazza66 in forum EnRoute
    Last Post: 10-05-2009, 10:25 PM
  3. Pin array
    By sp1nm0nkey in forum Mastercam
    Last Post: 07-05-2009, 03:27 AM
  4. L10 cut array command
    By RossMColquhoun in forum G-Code Programing
    Last Post: 03-05-2009, 01:59 AM
  5. Array with v20
    By DEW in forum BobCad-Cam
    Last Post: 11-21-2007, 12:50 AM
