587,781 active members*
2,862 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 1000 tool change problem!
Results 1 to 8 of 8
    Feb 2011
    Hi All.
    Our company have an old Cincinnati arrow 1000, with milacron 2100 control system.
    We bought the machine second handed, and have had many problems with it!
    Now a new problem has come up. The machine Can not make a tool change.
    The Z axis is going too tool change pos, and the tool drum is turning to the required tool, but the spindle is aligning to the wrong position, and then the machine just stops. There is no more movement, and no alarm appears!
    We got the problem and couldn't fix it, but then when I turned on the machine the next day the problem was gone! Now the problem is back, and it dos not seem to go away by it selves again.
    We have checked all relays, switched the disc to a system backup disc and tryed to switch the spindle drive unit with one from a simmilar machine, but nothing has worked!
    Anyone who has any idea of what the problem Can be? Any help is appriciated!
    Apr 2008
    17
    What version software are you running and how old is the machine
    Feb 2011
    The machine is produced in 1997. About the software version, I'm not quite sure. Where can I see this information?
    Is it possible that the temperature can course this problem? The temperature here is around the freezing point, 0°C. Actually the tool change has worked fine, for the last couple of days.
    Apr 2008
    17
    Temperature can be a problem but not in this case i think
    Touch more service and the software version will be there
    If it is 3.25 then we can move forward to fix otherwise we will have to look at other options
    Apr 2008
    17
    where are you that you are running at 0 degrees
    Feb 2011
    The base system software is 2.34
    I'm in china.
    Sep 2010
    1765
    1997 machine. possibly loosing P1 position randomly now after 14 years......
    The Batt back ram chip used to store the program and variables in the vfs5 had a planned life of 7 years. Sounds like your BRAM is in need of replacement. We do it here in the US, Millardfiz can do it in UK, not sure who in your area. If you simply replace the chip the drive is dead - stuff needs to be copied over to new one (password protected too)
    Feb 2011
    I am looking to buy a vertical machine centre,what make would you recomend?
  1. Arrow 1000 Y axis problem / Vickers AS10300 codes
    By Chaz in forum Cincinnati CNC
    Last Post: 02-24-2020, 08:31 PM
  2. Arrow 500 spindle tool change position
    By mmckell in forum Cincinnati CNC
    Last Post: 02-15-2011, 09:56 PM
  3. Tool Change Problem
    By el_maquinista in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-30-2011, 05:33 AM
  4. cincinati arrow 1000 tool absent switch
    By stuart wiezniak in forum Cincinnati CNC
    Last Post: 01-13-2011, 01:03 AM
  5. Arrow 500 AC2100E Tool Data problem
    By aadonline in forum Cincinnati CNC
    Last Post: 09-27-2010, 11:16 PM
