603,870 active members*
3,263 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 500 Slow DNC upload to machine, also slow processing of g-code
Results 1 to 4 of 4
    Jun 2014
    12
    I am having an issue with the DNC mode on my Arrow 500 with CT control. When I am running a program it will get to a point where the machine will only load about 15 lines, run them, pause, load 15 lines, run them, pause...etc. Also along with this it runs the G-code very slow, so if the machine is running a linear interpolation of an arc, the machine XY table stutters as it processes each g-code line and goes really slow. This will end up causing me to wear out tools really fast.
    Does anyone know how to speed this up or can give me suggestions on what to do?
    Dec 2006
    585
    Re: Arrow 500 Slow DNC upload to machine, also slow processing of g-code
    You may have to reload the software or the axis following error on any of the axis may be to high. The control has a window for the axis following error and if any axis is outside that window it will stop until the axis drifts into that window. Look at each axis following error, you should see 3 to 5 counts when the axis is stopped.
    Mike cncmachineservices (dot) com
    Jun 2014
    12
    Mike,
    I've sent you an email, also tried to call you. Let me know if you can help. Thanks again
    Dec 2006
    585
    We did not receive you e-mail or your call. You can reach us at our web site cncmachineservices (dot) com
    Mike
  1. Unwanted slow feedrates in code
    By AvB in forum MadCAM
    Last Post: 06-20-2014, 05:34 AM
  2. Replies: 4
    Last Post: 10-26-2013, 02:03 AM
  3. Limit/Home wiring and how slow is slow?
    By Michaelofburien in forum DIY CNC Router Table Machines
    Last Post: 05-24-2013, 07:44 PM
  4. machine oiler, slow
    By Brian FRF in forum Milltronics
    Last Post: 08-18-2009, 06:25 PM
  5. Slow machine response inquiry
    By spoiledbrat in forum Mach Mill
    Last Post: 01-30-2007, 03:05 PM
