603,385 active members*
1,896 visitors online*
Results 1 to 5 of 5
    Nov 2004
    21
    ASCII to .dwg conversion?
    Has anyone out there been able to convert an ascii text file to a .dwg ?
    A friend wants me to help with some drawings but he cant send the files directly so they get converted into a .txt attachment.
    Any suggestions?
    TIA,
    Shaun.
    Aug 2004
    2849
    I seriously doubt that it will happen in this life time. What you need are binary files and then you'll need a post processor that can take the binary files and convert them to something meaningful........
    Jun 2004
    3
    Shaun,
    This sounds like a security issue. There have been so many viruses going around as of late that about the only file format that gets through are txt files. Have your friend resend you the files but have him rename the files say Test.DWG to Test.txt before he sends them to you. Most email/firewall systems don't actually read the file, they just check the extension - this should allow the files to pass through. Once you get them, just detach them and then rename back to Test.DWG.
    HTH
    Todd
    Nov 2004
    21
    Thanks Todd,
    thats actually what I did. i was surprised when it didnt work. i was able to have him resend the documents individually and retain the extension which allowed me to open them in autocad.
    while i was researching the problem i found some interesting ascii tricks:
    http://abstract.cs.washington.edu/~r...matrix.html.gz
    Jul 2003
    28
    We use ASCII files to import and export points from the Survey package. Not sure what type of info the ASCII he's creating would be.
  1. Need Advice for Clone Conversion
    By lerman in forum Bridgeport / Hardinge Mills
    Last Post: 04-17-2006, 07:48 PM
  2. First Impressions for CNC mini mill conversion
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 03:37 AM
  3. Newbie Looking for Advice (Sherline or HF Conversion)
    By Deviant in forum Benchtop Machines
    Last Post: 09-27-2004, 02:10 AM
  4. Mini lathe conversion
    By kdoney in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2004, 04:21 AM
  5. possible cnc conversion on homier mini mill
    By WsW-WYATT in forum Benchtop Machines
    Last Post: 03-27-2004, 02:24 PM
