603,975 active members*
3,346 visitors online*
Results 1 to 9 of 9
    Apr 2006
    118
    Asking for a G code sample
    I've been looking up G-code info on the web and slowely getting some ideas on how to run my machine with G code. Anyhow I only run the X and Z axis and only one motor turns at a time. Right now I run my system with its own on board servo command mode but it has limits that I need to find a way to avoid.
    For what I do the torque setting will always be the same. Velocity and the # of steps is about all that changes.
    My motion profile looks some thing like this:
    X steps 1000 CW Vel 100
    Z steps 30000 CCW Vel 500
    Z steps 30000 CW Vel 50
    Time delay 2 min.. no motion
    Z steps 10000 CCW Vel 500
    Z steps 10000 CCW Vel 100
    Time delay 30 sec.. no motion
    X steps 1000 CCW Vel 100
    This is the basic motions that I run. Each motion has a fixed acceleration profile to it as well.. In other words if I want to change velocity going from point A to point B my current system veiws this as another motion profile. As in accelerat to speed, decelerat,stop ( milliseconds ) accelerat to new speed
    ... so on and so on. This is a pitfal I would like to get away from and hope that G-code makes this possable.
    Any input would be great!
    Bill
    Apr 2005
    3634
    I'm not really sure what you want.
    Anyway some basics:
    (1) If you want more than one axis to move at the same time, put both commands on the same line.
    G01 X-5.0 Z-1.5 F50
    Breakdown of above code:
    (A) G01 (Linear Interpolation)
    (B) X-5.0 Z-1.5 (Move the "X" & "Z" axis the specified distance)
    (C) F50 ("F" stands for Feed, so the Feed here is equal to 50 mm/in a minute)
    If you want to pause a program with no axis movement:
    G4 F120
    (A) G4 (Dwell Time)
    (B) F120 (Pause for 120 seconds)
    Sample:
    X (Distance to travel (+/-)) F100
    Z (Distance to travel (+/-)) F500
    G4 F120 (Time delay 2 min.. no motion)
    Z (Distance to travel (+/-)) F100
    G4 F30 (Time delay 30 sec.. no motion)
    WARNING
    This is just a sample , I have NO idea what your machine/control setup is, Run at your own risk
    Plus an actual program has more code.
    Free DXF - vectorink.com
    Dec 2003
    24260
    Bill.Also see your first post on the related subject.
    Al.
    Albert E.
    Apr 2006
    118
    Thanks guys for the input!.. this helps me. For some more detail of the motors I use, they each have there own on board controller, They where fast and easy to get up and running and required very little brain power on my part. Anyhow my machine only moves on the X and Z axis. All it does is dip a part in a selection of chemical tanks. Only one motor needs to run at any one time. NEVER at the same time like one needs for a router.
    I'll study some more on the web and come up with some more focused questions if you folks don't mind.
    Bill
    Apr 2006
    118
    Switcher,
    Does G01 command apply when you are moving only one motor? What command defines direction of motor rotation?
    Bill
    Apr 2005
    3634
    The answer is, yes. Also I believe some controls don't require you to use "G01" (an option) while others do require it. I always use it out of habit anyway.
    (A) To rotate a motor clockwise use the ( + )
    (B) To rotate a motor counter-clockwise use the ( - )
    Example:
    G01 X+5.0 F50
    G01 Z-1.5 F50
    (The sample would make the "X" motor spin clockwise, and the "Z" motor would spin counter-clockwise)
    Again, I believe some controls don't require you to use " + " (an option) while others do require it.
    As far as the negitive sign ( - ), I think all controls require you to use that.
    So the sample above, could also look like this:
    G01 X5.0 F50
    G01 Z-1.5 F50
    Notice the ( + ) missing from (X+5.0)
    If your just starting out, with g-code I would recommend keeping the ( + ) & ( G01 ), to keep the program as clear to you as possible.
    Again as far as what way a motor spins clockwise/counter-clockwise would all depend on how your machine is built ( If the above doesn't work for your setup, try reversing them ( - ) & ( + ) in your code.
    Keep your ( F ) very low when practicing, your code. Then when you get the path correct, crank up your Feed. Just be cautious at first
    Apr 2006
    118
    Switcher,
    X-5.0 Z-1.5 (Move the "X" & "Z" axis the specified distance) The 5.0 and 1.5 is this the number of steps? or a distance assuming a certian mechanical set up?
    Bill
    Apr 2005
    3634
    That would be Linear moves (distance to travel), in either millimeter or inch, depending on what you set your control up with.
    You could use the same examples and switch the Linear, and instead have a rotary axis such as "A axis". Then it would be in degree.
    Example:
    G01 A-360 F50 ("A" would rotate counter-clockwise, 360 degree, at a Feed rate of 50 mm/inch a minute)
    Just curious , do you have any photos of your setup?
    Apr 2006
    118
    Right now no.. its 3000 pounds, 50+ sq ft of floor space and 7 feet tall. Lots of pumps, heaters, ventelators and a low tech load lock to keep the nasty stuff inside and away from the operator.
