603,940 active members*
2,162 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire and mach3
Page 1 of 2 12
Results 1 to 20 of 21
Hybrid View
stk2008 Aspire and mach3 01-25-2011, 08:41 PM
EBC ck material setup, ck tool... 01-25-2011, 11:00 PM
stk2008 Hey thanks for the reply. ... 01-25-2011, 11:53 PM
ger21 Without seeing the files,... 01-25-2011, 11:59 PM
stk2008 Oh damn ummm don't know what... 01-26-2011, 12:06 AM
ger21 As mentioned above, ask at... 01-26-2011, 12:18 AM
stk2008 OK registered on there forum... 01-26-2011, 12:45 PM
ger21 I can't think of anything... 01-26-2011, 01:07 PM
stk2008 Well this is a complete loss.... 01-26-2011, 01:14 PM
ger21 post your g-code. 01-26-2011, 05:57 PM
stk2008 Hi again Ger21 here it is ... 01-26-2011, 06:16 PM
blowlamp Hi, stk2008. I can't tell... 01-26-2011, 10:51 PM
stk2008 Hello and thanks for taking... 01-26-2011, 11:11 PM
ger21 There's something going on in... 01-26-2011, 11:54 PM
stk2008 Hi again Ger21. I really... 01-27-2011, 02:03 AM
EBC Aspire works... If you are... 01-27-2011, 02:19 AM
stk2008 Hi EBC I dont think its the... 01-27-2011, 10:14 AM
Mark_Moran Hello, Just to let... 01-28-2011, 11:38 AM
stk2008 Hi Mark_Moran I just came... 01-28-2011, 03:53 PM
Mark_Moran Hello stk2008, I was using... 01-28-2011, 05:04 PM
stk2008 Hi again yeah I know :) any... 01-28-2011, 06:31 PM
    Mar 2007
    398
    Aspire and mach3
    Hi all I was looking at Vcarve/Aspire and some one I know who makes signs said he has it.
    So I went there to pick up his laptop to have a play.
    The problem I have is when I do a machine run through in Aspire (2.5 btw)
    it looks fine as soon as I get it into mach3 its all screwed up and would cause a major crash.
    here is a pic of the Aspire
    and now in mach3
    as you can see the cuts drop loads and if I was to run this for real then I would plunge into the work piece lucky for me I am only looking at the out put via mach3 and not sending it to a machine.
    any ideas please as I dont have long as when he is back he will want his laptop back
    Thanks all
    the PP I used is
    Mach2/3 Arcs (ince) (*.txt)
    Mar 2008
    177
    ck material setup, ck tool database parameters, ck tool data for correct depth in aspire. also suggest you post on vectric forum
    Mar 2007
    398
    I have checked as much as I can its odd that it shows good in Aspire but then when it gets to mach3 it goes mad.
    Any one got an answer? or some thing else I can try next.
    thanks
    Mar 2003
    35494
    Without seeing the files, it's very hard to guess what's going on.
    Many, many users use Aspire with Mach3 with no problems. Myself included.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2007
    398
    Oh damn ummm don't know what to do.
    I can send ya a file that cocks up for me and if you don't mind test it for me .
    Though saying that why am I having troubles and my mate never said about it to me?.
    Mar 2003
    35494
    As mentioned above, ask at Vectric's forum and you might get an answer quicker.
    Gerry
    Mar 2007
    398
    OK registered on there forum still waiting for an admin to activate me account takes ages hahahaha.
    Any thing I could try in the mean time as he will be back for his lappy soon
    Mar 2003
    35494
    I can't think of anything that could give you one toolpath in Aspire and a diffrent one in Mach3. Unless you have another in Aspire that isn't shown and you're exporting the wrong one?
    Gerry
    Mar 2007
    398
    If I import a bitmap for tracing then create a profile cut around it as per pics on me first post in Aspire its fine.
    In mach3 it comes out as me second pic with the blue lines dropping randomly around the cut.
    Mach3 version is
    Version R3.042.020
    OK this is another example
    in Aspire made with just the curve draw tool
    in mach3
    in aspire
    in mach3
    so as you can see for some reason in mach3 it decides to randomly lower the Z axis though in Aspire it show it as being perfect.
    Mar 2003
    35494
    post your g-code.
    Gerry
    Mar 2007
    398
    god.txt
    Thanks very much mate.
    May 2008
    266
    Hi, stk2008.
    I can't tell you what's causing that to happen, but it looks like Mach is showing the right toolpath.
    Pic shown below is of your gcode, backplotted in CamBam.
    Martin.
    Mar 2007
    398
    Hello and thanks for taking the time to test my Gcode.
    Um so even in CamBam (did not think of trying it in there) it still does it.
    This is very weird because as you can see in Aspire it looks perfect.
    Thanks again
    EDIT
    You may or may not be interested but this is the thread on the Vectric forums
    http://www.vectric.com/forum/viewtopic.php?f=27&t=10387
    Mar 2003
    35494
    There's something going on in your friends version of Aspire.
    I opened Aspire, and created a similar shaped curve, and created a multiple pass toolpath. Opened in Mach3, it looks exactly the same as in Aspire.
    In yours, the Z depth is changing on nearly every line of code. The profile toolpath doesn't do that.
    Has your friend perhaps made some strange modifications to the post processor?
    And btw, next time, upload the .txt file here, so I don't have to deal with 2 or 3 pop up windows to get it.
    Gerry
    Mar 2007
    398
    Hi again Ger21.
    I really could not tell you if he has changed that.
    Would you be able to or any one be able to post me the mahc3 PP I use inch so the ATC and none ATC post would be great (fingers crossed he has been a numpty and messed with it or prey to god it wasn't me...there's a thought :O maybe I did some thing as he never said of this issue to me)
    at least if I have another copy of it and it still does this then I can then move on to some thing else to try and figure this issue out but till I get a fresh PP then I think I should be looking there.
    Thanks Ger21.
    Mar 2008
    177
    Aspire works... If you are having a issue with the Mach PP then email Vectric support. They will help figure out your particular issue, if you have a valid copy.
  17. #17
    Mar 2007
    398
    Hi EBC I dont think its the post as I tried the Gcode post and it does the same and on Vectric website they say that the Gcode post should still work in Mach3.
  18. #18
    Jan 2011
    Hello,
    Just to let everybody know the answer to this one.
    The copy of the software on stk2008's "friends" laptop, turned out to be a "corrupted" copy that was obtained from a source other than Vectric or one of their OEM partners.
    This is why other users that tried to replicate the problem that stk2008 was seeing,
    were unable to do so.
    Cheers,
    Mark.
  19. #19
    Mar 2007
    398
    Hi Mark_Moran I just came back in here to tell every one the problem to put straight that it was NOT your software.
    You say corrupted but lets tell them the truth I believe it was a dodgy copy and I sent you an email saying I confronted my friend over this he did not seem to want to talk about it.
    So I am very very sorry every one I can only apologise for all the confusion I have caused and would like to point out that I had no idea that this was a possible (more than likely was) cracked copy.
    Thanks and sorry to all.
  20. #20
    Jan 2011
    Hello stk2008,
    I was using "corrupted" as a euphemism.
    Cheers,
    Mark.
Page 1 of 2 12
  1. Aspire V2 y Cut 3D
    By bigsergio04mex in forum Spanish
    Last Post: 03-17-2012, 07:23 AM
  2. aspire, vcarve pro
    By cabnet636 in forum Commercial CNC Wood Routers
    Last Post: 03-16-2009, 10:56 PM
  3. Aspire!!!
    By cabnet636 in forum Vectric
    Last Post: 02-23-2009, 06:15 PM
  4. 15 minute Aspire?
    By bsimages in forum Vectric
    Last Post: 01-30-2009, 02:51 PM
