587,997 active members*
1,819 visitors online*
IndustryArena Forum > CAM Software > UG NX > assembly in nx-6
Results 1 to 5 of 5
    Sep 2008
    27
    Unhappy assembly in nx-6
    I am playing with nx-6 assembly but I am unable to assemble parts properly, how can we see/delete/on-off the added constrains like nx-4,before that I was using nx-4.
    Thanks,
    Dec 2006
    77
    In NX5 there was a change to the assembly proceedures. My best advice is spend 30 minutes with UG Cast on assemblies. This will explain the new functionality and where everything is located.
    Brian
    Jan 2008
    30
    Hi, we just made the switch to NX6 (from 5). I'm not sure about NX4, but you can switch back to the "Mating Conditions" you see in version 5 by selecting the following from the top menu bar in NX:
    -Preferences
    -Assemblies
    -In the "Assembly Preferences" box that pops up, in the bottom
    pulldown box called "Interactions" you can select between "Assembly
    Constraints" (new) and "Mating Conditions" (old).
    I have not figured out how to keep theese settings when you exit out and come back into NX, so I have to remember to set it every time.
    Hope this helps.
    It is the poor craftsman that blames the tool
    Feb 2006
    146
    You can set the preference under the customer defaults
    File - Utilities - customer defaults
    Select the Assemblies section - Extras - You can use assembly constraints or Mating Conditions. I would suggest using Assembly constraints. You can convert your existing assemblly mating conditions to assembly constraints. they are not hard to use.
    Read the help doc's
    The best way to see the constraints is 1. Make sure the constraints display option is active on the assembly navigator. Right click in an empty area of the Assy Navigator and make sure the Include Constraints option is active. 2. When you select a component and want to see it's constraints expand the dependencies panel at the bottom of the navigator and click on details, the magnifying glass.
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
    Mar 2010
    Thanks brother! I just needed a refresher!
  1. Need help with assembly please
    By dpark1 in forum Solidworks
    Last Post: 07-26-2008, 03:43 PM
  2. Re-assembly of X-2???????
    By Smitty911 in forum Benchtop Machines
    Last Post: 07-13-2007, 11:16 PM
  3. Z axis assembly
    By xlukkajr in forum DIY CNC Router Table Machines
    Last Post: 10-19-2006, 07:21 PM
  4. jgro assembly
    By drfoz in forum Commercial CNC Wood Routers
    Last Post: 09-07-2006, 12:50 AM
