To start, I have an Okada VM460, with Fanuc 3M controller
In process of doing a drip-feed upgrade, parameters & programs got erased.
We had the parameters recorded, and where able to get them back in, and make the drip feed work, but the only thing was the ATC wouldnt change out tools. Would get to the command line for a tool change, and hang there with no error lights or anything, just hung there, and cycle start light stayed on.
Searched for solutions everywhere, and in a bit of trial, my friend who is good with electronics, said to pull the PC1 card, and see what error codes came up, cause he was guessing it was associated with the ATC.
PC1 card was removed (yes with the power off)
Powered up machine to the ATC Alarm, and dry run lights on. nothing worked.
Put PC1 card back in, and started it back up, screen came up with garbage, and the same two lights were on, and then the smell of something burnt.:nono:
Pulled card again to get the following situation.
The Card is labeled A20B-0008-0630 A
I have attached pics, but new here so dont know if i did it right.
Anyone know where i can find replacement card, cause not haveing any luck.
Also, do i need to replace it with exact same card, or can i use an upgraded card?
I notice there are other cards that start the same A20B-0008- but last part is different.
Any help or advice is greatly appreciated!![]()
