603,360 active members*
4,470 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > ATC Will Not Move To Spindle
Results 1 to 8 of 8
    Jul 2006
    741
    Hi all,
    Got a problem, a "ATC will not move to spindle" message. The issue seems to be with releasing the tool. Manual changes are okay. Loading a tool from the ATC when the spindle is empty is okay. Unloading a tool in the spindle to the ATC does not work. Thoughts?
    I know next to nothing on machine maintenance and troubleshooting, so please feel free to dumb down things a bit for me... LOL Thanks!!!
    EDIT: The machine is a VMC15
    https://youtu.be/pJ-rHTcolkQ
    Mar 2008
    684
    Re: ATC Will Not Move To Spindle
    Looks like your Z height is off and bumping in to the tool holder. You can adjust the height using the SV command.
    Here is the manual that explains it.
    http://www.flintmachine.com/pdfs/fad...ey_Command.pdf
    Dec 2003
    180
    It could be the spindle dogs aren't lining up. Check to make sure they align with the center of the tool carousel. The maintenance manual has pretty clear instructions for this.
    Jan 2015
    417
    When you do a CS are the Z axis ColdStart lines on the side of the head lining up?
    Did some one Remove the Z axis motor ( usually for Shipping and or to get the machine through a doorway or Low ceiling) And when the motor was put back on they didn't get the coupler in the correct orientation. The CS will be off .100 (half a turn)
    get on a ladder behind the machine and look at the coupler on the z axis and see if the Marks line up you may have someone jog the machine. If they are not just take the 4 bolts holding the motor on and correct the couplers orientation .
    Jul 2006
    741
    Yes, it seems that the issue is lining up the Z to the correct height. Strange because the machine was working fine till Sunday. Monday I spent 1/2 the day doing manual tool changes.
    Back when I put the machine to work a few months ago the Z on CS was off. I adjusted the encoder and it worked fine till now. It is strange that it seems to be off again.
    EDIT: The witness mark is indeed off by 0.1". But it used to work before... strange. Or may be I'm confused as to how off it was before. I know it was not perfect, but it might have been off by a bit less. Should I have a go at the encoder again? Or perhaps one of the other suggestions above? Thanks!!
    Jan 2015
    417
    Try This Ed after you do your CS. jog your z down .200 and then do another CS.
    Now if you wanted to you can reach up into the main ATC (MAKE SURE NO ONE is on the keyboard if they push a button jog button it will pull the tool carriage back!!!!) cover and pull the arm and manually make the tool carriage move towards the spindle so you can physically see the misalignment.
    OR with the Machine powered Off you can pull the carriage out the same way. And don't worry when you power back on it will pull the carriage back home. if you forget
    Jul 2006
    741
    Quote Originally Posted by rodney247 View Post
    SUPER GENIUS !!!!!!!!!!!!!!!!
    That did it.
    Thank you so much Rodney!!
    Jan 2015
    417
    Hey your welcome Ed.......... glad i could help!!
  1. Replies: 0
    Last Post: 03-12-2016, 08:30 AM
  2. Replies: 2
    Last Post: 11-11-2015, 01:55 PM
  3. Replies: 6
    Last Post: 03-14-2011, 09:41 PM
  4. Replies: 5
    Last Post: 02-12-2010, 01:16 AM
  5. cog belts that move when spindle changes direction
    By FanucIssues in forum MetalWork Discussion
    Last Post: 07-26-2009, 08:42 AM
