587,302 active members*
3,318 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Attaching chuck to electric motor
    Jul 2008
    4
    Hello everyone,
    I am trying to design deburr machine to clean up 19mm hole after some drilling across it. So far I found the motor, etc to drive the brush but I am stuck on the chuck and attachment of the chuck to motor shaft. Can anyone recommend any chuck and attachment ideas? The shaft diameter on the motor selected is 11.5mm with 30mm sticking out of the motor.
    Thanks.
    Jan 2004
    3154
    forget the chuck.
    Make it like a rigid shaft coupling.
    www.integratedmechanical.ca
    May 2007
    781
    Were it me I would forget the idea of building something and just find a nice used second op lathe.
    HARDINGE DV-59 High Speed Shop Lathe BK model | eBay
    If your time is worth anything it will be cheaper.
  1. Most efficient electric motor?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 11-17-2014, 05:19 AM
  2. Need help attaching Keyless chuck to arbor
    By thrasherfox in forum Uncategorised MetalWorking Machines
    Last Post: 05-31-2011, 04:01 AM
  3. Help Attaching A ER-Collet Chuck to Motor Shaft
    By Brenck in forum Mechanical Calculations/Engineering Design
    Last Post: 02-11-2011, 01:26 AM
  4. attaching an encoder to stepper motor
    By serry in forum Stepper Motors / Drives
    Last Post: 01-25-2005, 10:37 PM
