586,069 active members*
3,469 visitors online*
Results 1 to 8 of 8
    Sep 2011
    39
    AUTO-ZERO PROGRAM NOT WORKING
    I have been trying for several weeks to set up the auto-zero function in Mach 3. I have tried several scripts, which I am sure work ok (from the amount of positive comments)
    My spindle is earthed, so I only use 1 cable to the touch-plate. On the diagnostics screen the digitize light lights up when the plate touches the bit. But, when I run the script, the spindle actually moves up.
    I have changed my screenset and put an indicator light beside the auto-zero button. I have noticed that this light flickers very briefly for no apparent reason. Does this mean that I have a short somewhere?
    Electronics is not my strongest suit, so I would appreciate any help you can give me.
    Thanks,
    Gareth
    Nov 2012
    1267
    Re: AUTO-ZERO PROGRAM NOT WORKING
    Quote Originally Posted by Gareth52 View Post
    That probably means you have electrical noise. What kind of breakout board you have? Does it have optocouplers on the inputs? What is the input logic voltage?
    P. S. I'm sure someone will soon tell you to use "debounce" function in Mach3 settings. While it MIGHT help in some situations, it only masks the underlying noise problem instead of fixing it.
    Sep 2011
    39
    Thanks for your reply. I can't remember the make but i know that inputs and outputs are optically isolated. i believe the voltage in question is 5 v.
    The debounce function is worth a try,but as you say, it does not solve the underlying cause. I would like to b e able to do that.
    Regards,
    Gareth
    Mar 2003
    35538
    Debounce does not apply to the probe input in Mach3.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2011
    39
    so it can't be that. Do you think it is worth trying a shielded cable?
    Jan 2020
    12
    I had a LOT of trouble with background electrical noise on a GRBL machine affecting the homing (same as probing). Shielded cable made a huge difference. Just ground the shielding material or it will be in vain! I used a little $70 oscilloscope from ebay to "see" the noise in order to diagnose the problem and see it fixed. I also ended up putting isolation transformers on the microcontroller supply, but that probably doesn't apply to your problem. This was all occurring in an electrically noisy factory when 3 sister machines were on the same circuit...
    Sep 2011
    39
    Thanks for that info. i have ordered some shielded cable.
    Gareth
    Sep 2011
    39
    [B]SORTED
    I used shielded cable, grounding the shield to the controller case and the problem was cured.
    thanks for all inputs.
    regards,
    Gareth
  1. Auto stop tabs don't aren't working. Z keeps going up ....Any Help?
    By stevelkneivel in forum Excitech routers
    Last Post: 02-14-2021, 03:33 AM
  2. RDworks V8- does anyone have working auto focus?
    By GeneMpls in forum Laser Control Software
    Last Post: 05-30-2016, 05:46 PM
  3. M5 not working in Auto
    By craig18712 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-08-2015, 06:48 PM
  4. TAKISAWA TK2 FANUC OMC - SP NOT WORKING IN AUTO
    By rajesh_1355 in forum Fanuc
    Last Post: 01-02-2010, 02:42 PM
