603,836 active members*
3,115 visitors online*
Results 1 to 4 of 4
    Dec 2014
    187
    AutoLaser 2.1.7 - Reverse before Saving
    Not sure if all Laser software is like this but if I draw or type any text in AutoLaser it has to be Flipped otherwise it engraves/Cuts the results backwards. So it I type CNCZone and save to Laser the Laser cuts/engraves it as enoZCNC ... Can't find if there is a simple method of automatically flipping it rather then remember and learn that everything I do has to be flipped before saving?
    Aug 2011
    41
    Re: AutoLaser 2.1.7 - Reverse before Saving
    Please, you need to post more info.
    Is Autolaser do the job in a normal way anytime ? or for the first time es reversed ? just text or any figure, rectangles, etc ?
    When you do a "home" you will note any changes of head movements ? the head changed the point (home) ?
    First of all I will check the system setup in Autolaser and try to find "flip x axis" or "flip horizontally" or something similar
    Martin.-
    Sep 2015
    7
    Hi ken,
    I'm having a similar issue. If I draw a rectangle in the top right (AutoLaser) the laser runs it OK.
    If I then add a circle to the top left the laser is flipping/mirroring the file.
    Is this the same as your issue?
    Thank you.
    Dec 2014
    187
    Quote Originally Posted by maker2015 View Post
    Hi ken,
    Yes I went through that as well, Kept on forgetting to Flip everything before lasering. Here is the Solution.
    Make sure the "Ïnside to Out" is checked under "Download/<<" see attached Image
    Attachment 324452
  1. AutoLaser not working properly
    By dwagar in forum Redsail Laser
    Last Post: 10-14-2016, 07:47 AM
  2. Unable to open AI files at AutoLaser
    By Frankie0808 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2016, 08:25 AM
  3. AutoLaser 2.1.3 - Trimming or removing a line
    By KenR60 in forum Laser Control Software
    Last Post: 02-19-2016, 04:07 AM
  4. FYI - RD Works, AutoLaser, LaserWorks program
    By tauscnc in forum Laser Control Software
    Last Post: 11-20-2015, 05:46 PM
  5. AutoLaser 2.0.8
    By thefitz in forum Laser Control Software
    Last Post: 06-22-2015, 05:37 AM
