Try as I might, I can't seem to create or modify a file.
It offered a save file menu, but no file was created. What have I done wrong?
How does it handle the deep routed paths for the outline?
Here is the code I tried, which was generated by my PCB editor, and works fine in Mach3.
Code:
( ---- \\_XQK\\PCB\\CPAP\\HEAT1206.NC ----)
(G-Code generation for : HEAT1206.BPC)
/G52 X0 Y0 Z0 (CANCEL any CRAZY SCALING)
G0 G80 G90.1 G17 G64
G59 P12 (Pxx TABLE NUMBER HERE)
#500=500 (FEED TO Z SAFE)
#501=150 (FEED TO G81 DRILLING)
#502=150 (FEED FOR ENGRAVING)
#505=300 (FAST ENGRAVING IN FILL)
#503=20 (FEED FOR ROUTING)
#600=0.00 (CURRENT X LOCATION)
#700=0.00 (CURRENT Y LOCATION)
(== 1.40 PCB Material ==)
#800=12.70 (Z SAFE at RAPID)
#801=2.45 (G81 Z RETRACT)
#802=-0.11 (Z ENGRAVE)
#803=-1.80 (G81 DRILL DEPTH)
#804=-1.60 (G1 ROUTER DEPTH)
#805=2.00 (G1 Z RETRACT)
#806=12.70 (FINAL RETRACT HEIGHT AT FINISH)
#666=0.35 (ENGRAVING CUTTER DIAMETER)
(----- END of VARIABLE SETUP -----)
(--- START OF MACHINE MOVEMENT ---)
G0 Z#800 (FIRST MOVE ALWAYS UP TO SOMEWHERE SAFE)
G0 X#600 Y#700
(0.35mm ENGRAVING CUTTER)
M6 T1 (INSERTED ENGRAVING CUTTER at Z0)
(SET ZERO TOP OF PCB, CYCLE START)
M3 S3600
M00 (TURN ON MOTOR 3600RPM)
G0 Z#800 (SAFE RAPID)
G1 Z#801 F#500 (FEED DOWN TO RETRACT)
F#502(START OF ENGRAVING)
G0 X-0.076 Y-2.337
G1 Z#802 (Z ENGRAVE)
G1 Y-2.159
X-1.981
Y-19.152
X-0.076
Y-2.413
X-1.727 F#505
Y-18.898
X-0.330
Y-2.667
X-1.473
Y-18.644
X-0.584
Y-2.921
X-1.219
Y-18.390
X-0.838
Y-3.175
X-1.016
Y-18.136
F#502
G0 Z#801 (RETRACT UP)
G0 X-0.381 Y-19.228
G1 Y-19.050
X-0.889
Y-29.108
X-0.381
Y-19.304
X-0.635
Y-28.854
X-0.457 Y-29.007
X-2.134
Y-39.573
X-0.457
Y-29.261 F#505
X-1.880
Y-39.319
X-0.711
Y-29.515
X-1.626
Y-39.065
X-0.965
Y-29.769
X-1.372
Y-38.811
X-1.219
Y-30.023
X-1.295
Y-38.557
F#502
G0 X-2.286 Y-38.811
G1 Y-38.633
X-2.515
Y-39.548
X-2.286
Y-38.887
X-2.388
Y-39.294
G0 X-2.311 Y-38.608
G1 Y-37.236
G0 X-2.540 Y-37.160
G1 Y-38.379
X-13.462
X-13.894 Y-38.837
X-14.529 Y-39.268
X-15.088 Y-39.497
X-15.723 Y-39.599
X-15.748 Y-39.548
G2 X-18.466 Y-36.830 I-15.748 J-36.830
G1 X-18.339 Y-36.043
X-18.034 Y-35.382
X-17.932 Y-35.230
Y-25.857
X-16.510 Y-25.883
Y-20.447
X-49.505
X-61.874 Y-0.203
G0 X-39.573 Y-0.254
G1 Y-0.076
X-62.128
Y-1.245
X-39.573
Y-0.330 F#505
X-61.874
Y-0.991
X-39.827
Y-0.584
X-61.620
Y-0.737
X-40.081
Y-0.660
X-61.366
F#502
G0 X-39.954 Y-1.118
G1 X-39.116 Y-1.956
G0 X-2.388 Y-0.127
G1 Y0.051
X-39.319
Y-1.727
X-2.388
Y-0.203
X-39.065 F#505
Y-1.473
X-2.642
Y-0.457
X-38.811
Y-1.219
X-2.896
Y-0.711
X-38.557
Y-0.965
X-3.150
Y-0.838
X-38.303
F#502
G0 X-3.658 Y-0.965
G1 X-1.981 Y-2.540
G0 X-1.930 Y-2.997
G1 X-3.454 Y-1.397
G0 X-3.658 Y-1.575
G1 X-1.930 Y-3.327
G0 X-1.905 Y-3.683
G1 X-3.708 Y-1.880
G0 X-4.191 Y-1.778
G1 Y-2.159
G0 X-5.842
G1 Y-1.981
X-7.341
Y-3.480
X-5.842
Y-2.235
X-7.087
Y-3.226
X-6.096
Y-2.489
X-6.833
Y-2.972
X-6.350
Y-2.718
X-6.579
G0 X-5.867 Y-3.454
G1 Y-4.013
X-4.877 Y-3.988
X-6.655 Y-4.039
G0 X-6.960 Y-3.810
G1 X-4.902
X-4.343 Y-4.369
Y-4.470
X-5.842
Y-17.602
X-4.343
Y-4.724
X-5.588 F#505
Y-17.348
X-4.597
Y-4.978
X-5.334
Y-17.094
X-4.851
Y-5.232
X-5.080
Y-16.840
G0 Z#801 F#502 (RETRACT UP)
G0 X-4.115 Y-17.805
G1 X-3.810 Y-18.085
Y-19.152
X-4.318
G0 X-4.115 Y-17.805
G1 X-8.941
X-8.839 Y-17.932
X-40.411
Y-17.424
G0 X-40.005 Y-17.526
G1 Y-17.805
G0 X-39.726
G1 X-40.005 Y-17.526
X-44.145 Y-17.501
G0 X-44.196 Y-16.891
G1 X-44.450 Y-16.637
Y-14.732
X-44.196 Y-14.605
G0 Y-13.995
G1 X-39.954
Y-10.135
X-46.076
X-45.999 Y-10.262
X-40.157
Y-13.310
X-40.284 Y-13.437
Y-13.945
G0 X-39.954 Y-13.995
G1 Y-17.501
G0 X-39.726 Y-17.805
G1 X-8.484
G0 X-10.566 Y-18.212
G1 Y-18.034
X-12.294
Y-24.867
X-10.566
Y-18.288
X-12.040 F#505
Y-24.613
X-10.820
Y-18.542
X-11.786
Y-24.359
X-11.074
Y-18.796
X-11.532
Y-24.105
X-11.328
Y-19.050
X-11.430
Y-23.851
G0 X-10.490 Y-23.876
G1 Y-23.622
G0 Y-21.717
G1 X-3.632
X-3.124
Y-20.828
X-2.616
X-2.413 Y-20.625
X-2.210
Y-27.584
X-3.556
Y-29.362
X-3.937
Y-36.881
X-13.005
X-13.106 Y-37.313
X-3.581
Y-37.160
X-3.683 Y-37.084
X-13.081
X-13.056 Y-36.906
Y-36.449
X-13.157 Y-35.941
X-13.360 Y-35.433
X-13.792 Y-34.976
X-14.122 Y-34.646
X-14.605 Y-34.392
X-15.088 Y-34.188
Y-27.407
X-10.770
G0 X-10.897 Y-27.584
G3 X-6.731 Y-31.750 I-10.897 J-31.750
G0 X-6.960 Y-31.877
G1 Y-29.947
X-7.264
Y-30.404
X-7.137 Y-30.937
G0 X-7.417 Y-30.582
G1 X-7.290 Y-31.471
X-7.315 Y-31.902
X-7.290 Y-31.750
G2 X-10.897 Y-28.143 I-10.897 J-31.750
G0 Y-27.864
G3 X-7.010 Y-31.750 I-10.897 J-31.750
G0 X-7.417 Y-30.582
G1 X-7.696 Y-30.124
Y-26.695
Y-26.873
Y-26.365
X-6.071
Y-26.645
G0 X-7.087 Y-27.635
G1 Y-27.457
X-7.493
Y-30.023
X-7.087
Y-27.711
X-7.290
Y-29.769
G0 X-3.378 Y-26.772
G1 Y-26.594
X-7.595
Y-27.457
X-3.378
Y-26.848
X-7.341
Y-27.203
X-3.632
Y-27.026
X-7.087
G0 X-4.064 Y-27.737
G1 Y-27.559
X-4.648
Y-36.678
X-4.064
Y-27.813
X-4.394
Y-36.424
X-4.318
Y-28.067
X-4.343
Y-36.170
G0 X-3.912 Y-35.789
G1 X-2.134
Y-35.281
X-4.166
G0 Y-35.535
G1 X-1.880
G0 X-1.930 Y-33.909
G1 X-2.438
Y-33.147
X-1.930
G0 X-3.607
G1 X-4.115
G0 X-3.607
G1 Y-33.909
X-3.962
G0 X-3.861 Y-31.394
G1 Y-31.140
X-2.083
G0 Y-31.394
G1 X-3.861
G0 X-3.835 Y-29.362
G1 Y-27.584
G0 X-2.261 Y-21.107
G1 Y-20.930
X-3.099
Y-27.356
X-2.261
Y-21.184 F#505
X-2.845
Y-27.102
X-2.515
Y-21.438
X-2.667
Y-26.848
G0 X-3.023 Y-26.645
G1 X-3.048 Y-26.365
G0 X-2.515 Y-28.778
G1 Y-29.362
X-2.108
Y-37.160
X-2.540
G0 X-2.794 Y-38.811
G1 Y-38.633
X-13.310
Y-39.649
X-2.794
Y-38.887 F#505
X-13.056
Y-39.395
X-3.048
Y-39.141
X-12.802
G0 X-0.203 Y-39.776
G1 X-18.745
G0 Y-40.030
G1 X-0.203
Y-39.776
G0 X-0.178 Y-40.335
G1 X-18.745
Y-40.030
G0 X-19.253 Y-39.599
G1 X-17.602
G0 X-17.907 Y-39.853
G1 X-18.872 Y-38.964
G0 X-18.720 Y-36.830
G3 X-15.748 Y-39.802 I-15.748 J-36.830
G0 Y-40.056
G2 X-18.974 Y-36.830 I-15.748 J-36.830
G0 X-19.228
G3 X-15.748 Y-40.310 I-15.748 J-36.830
G0 X-15.037 Y-39.675
G1 X-14.148
X-14.173 Y-39.319
G0 X-14.046 Y-39.675
G1 X-13.970 Y-38.964
X-14.554 Y-39.497
X-15.037 Y-39.675
G0 X-14.046
G1 X-13.716 Y-39.700
X-13.691 Y-38.938
X-13.437 Y-38.608
X-13.462 Y-39.827
G0 X-6.934 Y-35.839
G1 Y-35.662
X-12.675
Y-36.576
X-6.934
Y-35.916 F#505
X-12.421
Y-36.322
X-7.188
Y-36.119
X-12.167
G0 X-6.883 Y-34.646
G1 Y-34.468
X-7.849
Y-35.585
X-6.883
Y-34.722
X-7.595
Y-35.331
X-7.137
Y-34.976
X-7.366
Y-35.077
G0 X-7.823 Y-35.103
G1 X-6.883 Y-33.960
G0 Y-33.477
G1 X-7.747 Y-34.773
X-8.763 Y-35.662
G0 X-8.382 Y-35.560
G1 X-7.823 Y-35.103
G0 X-12.878 Y-36.500
G1 X-13.056 Y-35.255
G0 X-14.148 Y-34.417
G1 X-14.808 Y-34.112
Y-33.426
X-14.529 Y-34.214
G0 X-18.085 Y-34.925
G1 X-18.491 Y-34.849
Y-35.687
G0 X-18.567 Y-36.093
G1 X-18.085 Y-34.925
G0 X-14.808 Y-30.277
G1 Y-27.711
X-11.862
G0 X-11.379 Y-28.143
G1 X-10.541
Y-26.416
X-12.319
Y-26.568
X-15.113
X-15.367 Y-26.314
Y-19.609
X-15.723 Y-19.253
G0 X-15.469 Y-19.152
G1 X-40.411
Y-19.355
X-41.656
X-42.926
X-44.196
Y-12.014
X-41.656
Y-14.300
G0 X-42.926
G1 Y-12.014
G0 X-42.621 Y-10.643
G1 Y-10.465
X-43.231
Y-11.760
X-42.621
Y-10.719
X-42.977
Y-11.506
X-42.875
Y-10.973
X-42.926
Y-11.252
G0 X-43.561 Y-9.017
G1 Y-8.763
G0 X-43.231 Y-6.629
G1 Y-6.452
X-43.891
Y-6.833
X-43.231
Y-6.629
X-43.637
G0 X-43.231 Y-4.724
G1 Y-4.547
X-43.891
Y-4.953
X-43.231
Y-4.750
X-43.637
G0 X-43.561 Y-2.667
G1 Y-2.413
G0 Y-1.524
G1 Y-1.270
G0 X-46.355
G1 Y-1.524
G0 Y-2.413
G1 Y-2.667
G0 X-46.025 Y-4.724
G1 Y-4.547
X-46.685
Y-4.953
X-46.025
Y-4.750
X-46.431
G0 X-46.025 Y-6.629
G1 Y-6.452
X-46.685
Y-6.858
X-46.025
Y-6.655
X-46.431
G0 X-46.355 Y-8.763
G1 Y-9.017
G0 X-45.644 Y-10.135
G1 X-48.819
Y-10.236
Y-6.223
X-49.047 Y-5.994
Y-5.867
X-51.333
Y-6.883
X-46.076 Y-15.646
Y-16.815
X-47.777
Y-15.545
X-48.717 Y-13.995
X-49.555
Y-12.725
X-50.444 Y-11.176
X-51.359
Y-9.703
X-52.146 Y-8.382
X-53.086
Y-6.782
X-53.696 Y-5.766
X-54.381
Y-4.242
G0 X-40.894 Y-2.997
G1 Y-2.819
X-54.686
Y-4.267
X-40.894
Y-3.073
X-54.432 F#505
Y-4.013
X-41.148
Y-3.327
X-54.178
Y-3.759
X-41.402
Y-3.531
X-53.924
G0 X-41.072 Y-3.581
G1 Y-4.851
X-40.132
X-40.818 Y-4.166
Y-4.572
X-40.538
G0 X-40.005 Y-4.648
G1 X-41.072 Y-3.581
G0 X-40.767 Y-2.921
G1 Y-2.413
G0 X-37.846 Y-2.210
G1 Y-2.032
X-39.319
Y-3.150
X-37.846
Y-2.286
X-39.065
Y-2.896
X-38.100
Y-2.540
X-38.811
Y-2.642
X-38.354
Y-2.591
X-38.583
G0 X-37.871 Y-3.302
G1 Y-3.734
G0 Y-3.531
G1 X-38.913
G0 X-38.583 Y-3.861
G1 X-38.456 Y-3.988
X-36.932
X-37.821
G0 X-38.125 Y-4.470
G1 X-36.398
X-36.297 Y-4.572
X-37.008 Y-3.861
X-38.583
G0 X-38.862 Y-4.191
G1 X-36.322
G0 X-36.347 Y-4.851
G1 Y-4.674
X-37.795
Y-17.628
X-36.347
Y-4.928
X-37.541 F#505
Y-17.374
X-36.601
Y-5.182
X-37.287
Y-17.120
X-36.855
Y-5.436
X-37.059
Y-16.866
G0 X-35.941 Y-15.367
G1 X-38.227
G0 X-39.624
G1 X-40.005
G0 X-41.656 Y-17.094
G1 Y-19.355
G0 X-42.926
G1 Y-17.094
G0 X-45.339 Y-17.526
G1 Y-19.050
X-45.593
Y-17.526
X-45.720
X-45.339
G0 X-45.847 Y-17.399
G1 Y-17.221
X-46.812
Y-18.796
X-45.847
Y-17.475
X-46.558
Y-18.542
X-46.101
Y-17.729
X-46.330
Y-18.288
G0 X-46.965 Y-18.390
G1 X-46.939 Y-17.297
X-47.727
X-47.041 Y-17.983
X-47.244 Y-17.348
G0 X-47.930 Y-17.145
G1 X-45.898
Y-10.312
X-48.997
G0 X-49.098 Y-9.754
G1 X-48.514 Y-10.643
X-46.076
Y-14.580
X-48.387 Y-10.795
G0 X-48.133 Y-10.744
G1 X-46.177 Y-13.970
G0 X-45.593
G1 X-45.339
Y-12.065
X-45.593
Y-13.970
G0 X-45.923 Y-15.265
G1 X-51.130 Y-6.807
Y-6.172
X-49.098
Y-9.754
G0 X-49.301 Y-8.890
G1 Y-8.712
X-49.632
Y-9.322
X-49.301
Y-8.966
X-49.454
Y-9.068
G0 X-40.005 Y-7.315
G1 Y-7.137
X-50.089
Y-8.611
X-40.005
Y-7.391
X-49.835 F#505
Y-8.357
X-40.259
Y-7.645
X-49.581
Y-8.103
X-40.513
Y-7.874
X-49.327
G0 X-40.767 Y-8.763
G1 Y-9.017
G0 X-40.005 Y-5.105
G1 Y-4.928
X-41.072
Y-6.858
X-40.005
Y-5.182
X-40.818 F#505
Y-6.604
X-40.259
Y-5.436
X-40.564
Y-6.350
X-40.513
Y-5.690
X-40.538
Y-6.096
G0 X-40.005 Y-6.985
G1 X-39.624
G0 X-38.227
G1 X-35.941
G0 X-33.655
G1 X-31.369
G0 X-31.775 Y-5.080
G1 Y-4.902
X-33.249
Y-17.602
X-31.775
Y-5.156
X-32.995 F#505
Y-17.348
X-32.029
Y-5.410
X-32.741
Y-17.094
X-32.283
Y-5.664
X-32.512
Y-16.840
G0 X-31.369 Y-15.367
G1 X-33.655
G0 Y-12.573
G1 X-31.369
G0 X-29.083
G1 X-26.797
G0 X-24.511
G1 X-22.225
G0 X-19.939
G1 X-17.653
G0 X-15.367
G1 X-13.081
G0 X-10.795
G1 X-8.509
G0 X-6.223
G1 X-3.937
G0 X-2.413
G1 X-1.905
G0 Y-9.779
G1 X-2.413
G0 X-3.937
G1 X-6.223
G0 X-8.509
G1 X-10.795
G0 X-13.081
G1 X-15.367
G0 X-17.653
G1 X-19.939
G0 X-22.225
G1 X-24.511
G0 X-26.797
G1 X-29.083
G0 X-31.369
G1 X-33.655
G0 X-35.941
G1 X-38.227
G0 Y-12.573
G1 X-35.941
G0 X-39.624
G1 X-40.005
X-40.132 Y-12.065
X-40.513
G0 X-45.339 Y-10.287
G1 X-45.720
X-45.644 Y-10.211
Y-19.050
X-46.939
X-49.047 Y-16.942
Y-16.688
X-49.301 Y-16.434
Y-14.681
X-49.911
X-51.029 Y-12.929
Y-11.913
X-51.689
X-52.832 Y-10.109
Y-9.093
X-53.518
X-54.610 Y-7.341
Y-6.299
X-55.270
X-55.626 Y-5.715
Y-3.632
X-54.762 Y-2.769
G0 X-54.813 Y-3.099
G1 X-55.397 Y-3.531
Y-6.096
G0 X-54.407 Y-3.658
G1 Y-3.480
X-55.169
Y-6.071
X-54.407
Y-3.734
X-54.915
Y-5.817
X-54.661
Y-3.988
X-54.788
Y-5.563
G0 X-54.483 Y-5.944
G1 X-54.508 Y-7.341
X-53.467 Y-8.865
X-53.492 Y-6.706
X-54.026 Y-6.020
X-54.280
X-54.153 Y-7.518
X-53.594 Y-8.407
X-53.696 Y-6.655
X-54.051 Y-6.096
X-53.797 Y-8.026
G0 X-53.975 Y-8.763
G1 X-51.689
G0 X-52.095 Y-8.814
G1 X-52.781 Y-8.992
X-52.553 Y-10.338
X-51.689 Y-11.532
X-51.867 Y-9.449
X-52.375 Y-8.865
X-52.476 Y-9.042
X-52.273 Y-10.490
X-51.841 Y-10.973
X-52.045 Y-9.322
X-52.273 Y-9.119
X-52.095 Y-10.744
G0 X-52.197 Y-11.557
G1 X-50.038
G0 X-50.444 Y-11.735
G1 X-51.003
X-50.775 Y-12.954
X-49.886 Y-14.300
X-49.911 Y-12.598
X-50.775 Y-11.811
X-50.495 Y-13.386
X-50.013 Y-13.843
X-50.165 Y-12.497
X-50.546 Y-12.065
X-50.267 Y-13.589
G0 X-50.419 Y-14.351
G1 X-48.387
G0 X-48.539 Y-14.656
G1 X-47.930 Y-15.596
Y-17.145
G0 X-48.235 Y-17.043
G1 X-48.209 Y-15.215
G0 X-48.489 Y-14.986
G1 Y-16.815
X-46.965 Y-18.390
G0 X-46.914 Y-18.720
G1 X-48.793 Y-16.789
Y-14.757
G0 X-49.047 Y-14.656
G1 X-48.539
G0 X-49.047
G1 Y-16.942
G0 X-50.571 Y-16.713
G1 X-50.775
Y-16.053
X-52.095 Y-13.970
X-52.451 Y-13.945
Y-13.462
X-53.924 Y-11.176
X-54.254
Y-10.668
X-55.651 Y-8.407
X-56.007
Y-7.950
X-57.150 Y-6.121
G0 X-57.404 Y-6.680
G1 X-49.022 Y-20.218
X-48.133 Y-20.244
X-49.936 Y-18.364
X-48.616 Y-20.244
G0 X-49.301 Y-20.295
G1 X-47.625 Y-20.447
X-50.571 Y-17.501
Y-16.713
G0 X-50.902 Y-16.408
G1 X-54.026 Y-11.481
X-55.728 Y-8.788
X-56.921 Y-6.756
X-57.277 Y-6.731
X-50.749 Y-17.170
G0 X-49.708 Y-14.300
G1 X-49.733 Y-12.700
X-50.444 Y-11.735
G0 X-51.435 Y-11.481
G1 X-51.638 Y-9.525
X-52.095 Y-8.814
G0 X-53.188 Y-8.687
G1 X-53.289 Y-6.731
X-53.873 Y-5.944
X-54.483
G0 X-53.721 Y-5.969
G1 X-53.340
G0 X-51.943 Y-4.699
G1 Y-2.413
G0 Y-1.524
G1 Y-1.270
G0 X-48.819 Y-1.651
G1 Y-1.473
X-49.479
Y-2.616
X-48.819
Y-1.727
X-49.225
Y-2.362
X-49.073
Y-1.981
X-49.149
Y-2.108
G0 Y-4.318
G1 Y-4.699
G0 X-49.276 Y-6.553
G1 Y-6.375
X-50.851
Y-7.163
X-49.276
Y-6.629
X-50.597
Y-6.909
X-49.530
Y-6.756
X-50.343
G0 X-50.216 Y-7.595
G1 Y-7.417
X-50.597
Y-7.849
X-50.216
Y-7.620
X-50.394
G0 X-47.066 Y-10.947
G1 Y-10.770
X-47.955
Y-11.735
X-47.066
Y-11.024
X-47.701
Y-11.481
X-47.320
Y-11.252
X-47.498
G0 X-46.406 Y-10.973
G1 Y-10.795
X-47.244
Y-13.335
X-46.406
Y-11.049
X-46.990
Y-13.081
X-46.660
Y-11.303
X-46.812
Y-12.827
G1 X-59.512 Y-3.683
G0 X-59.207 Y-3.581
G1 X-58.674 Y-4.699
X-58.750 Y-3.658
X-59.207 Y-3.861
G0 X-58.699 Y-1.651
G1 Y-1.473
X-59.868
Y-3.607
X-58.699
Y-1.727
X-59.614
Y-3.353
X-58.953
Y-1.981
X-59.360
Y-3.099
X-59.207
Y-2.235
X-59.284
Y-2.845
G0 X-59.919 Y-3.023
G1 X-59.995 Y-1.219
X-60.706 Y-1.473
X-59.969 Y-2.489
X-60.198 Y-1.194
X-60.630 Y-1.270
X-60.071 Y-2.032
G0 X-59.919 Y-3.023
G1 X-60.985 Y-1.295
G0 X-57.048 Y-1.549
G1 X-55.829
X-56.845 Y-2.565
Y-1.778
X-56.363
X-56.744 Y-2.159
G0 X-57.048 Y-1.549
G1 Y-2.972
X-55.423 Y-1.346
G0 X-54.737 Y-1.270
G1 Y-1.524
G0 X-57.125 Y-1.600
G1 Y-1.422
X-58.572
Y-6.629
X-57.125
Y-1.676
X-58.318 F#505
Y-6.375
X-57.379
Y-1.930
X-58.064
Y-6.121
X-57.633
Y-2.184
X-57.836
Y-5.867
G0 X-49.428 Y-20.295
G1 X-49.251 Y-20.930
X-17.170
X-17.145 Y-25.171
G0 X-16.891 Y-25.121
G1 Y-25.298
X-32.131
G0 X-29.820 Y-25.578
G1 Y-25.400
X-31.471
Y-26.264
X-29.820
Y-25.654
X-31.217
Y-26.010
X-30.074
Y-25.832
X-30.963
G0 X-30.023 Y-25.527
G1 X-16.815
Y-20.676
X-49.428
G0 X-38.278 Y-25.121
G1 X-16.891
G0 X-16.510 Y-25.756
G3 X-17.932 Y-27.178 I-16.510 J-27.178
G0 X-17.958 Y-26.416
G1 X-17.501 Y-25.832
G0 X-15.113 Y-27.407
G1 Y-19.507
X-15.469 Y-19.152
G0 X-13.487 Y-4.928
G1 Y-4.750
X-14.961
Y-17.653
X-13.487
Y-5.004
X-14.707 F#505
Y-17.399
X-13.741
Y-5.258
X-14.453
Y-17.145
X-13.995
Y-5.512
X-14.224
Y-16.891
G0 X-13.233 Y-18.059
G1 X-12.471
Y-18.567
X-12.979 Y-18.059
G0 X-13.233
G1 X-12.598 Y-18.694
Y-19.152
X-12.344
G0 X-4.115 Y-18.136
G1 Y-17.958
X-10.566
Y-19.152
X-4.115
Y-18.212 F#505
X-10.312
Y-18.898
X-4.369
Y-18.466
X-10.058
Y-18.644
X-4.623
Y-18.542
X-9.804
G0 X-5.969 Y-21.006
G1 Y-20.828
X-7.747
Y-21.565
X-5.969
Y-21.082
X-7.493
Y-21.311
X-6.223
Y-21.184
X-7.239
G0 X-5.969 Y-24.384
G1 Y-24.206
X-7.696
Y-24.867
X-5.969
Y-24.460
X-7.442
Y-24.613
X-6.223
Y-24.536
X-7.188
G0 X-10.770 Y-26.873
G1 Y-26.695
X-14.910
Y-27.711
X-10.770
Y-26.949
X-14.656
Y-27.457
X-11.024
Y-27.203
X-14.402
G0 X-12.802 Y-27.788
G1 X-14.732 Y-29.515
G0 X-13.919 Y-28.651
G1 Y-28.473
X-14.707
Y-29.159
X-13.919
Y-28.727
X-14.453
Y-28.905
X-14.173
Y-28.804
X-14.300
G0 X-13.106 Y-28.092
G1 Y-27.915
X-14.808
Y-28.473
X-13.106
Y-28.169
X-14.554
Y-28.219
X-13.360
Y-28.194
X-14.300
G0 X-8.915 Y-4.877
G1 Y-4.699
X-10.389
Y-17.678
X-8.915
Y-4.953
X-10.135 F#505
Y-17.424
X-9.169
Y-5.207
X-9.881
Y-17.170
X-9.423
Y-5.461
X-9.652
Y-16.916
G0 X-8.509 Y-15.367
G1 X-10.795
G0 X-13.081
G1 X-15.367
G0 X-17.653
G1 X-19.939
G0 X-22.225
G1 X-24.511
G0 X-26.797
G1 X-29.083
G0 X-27.203 Y-4.902
G1 Y-4.724
X-28.677
Y-17.780
X-27.203
Y-4.978
X-28.423 F#505
Y-17.526
X-27.457
Y-5.232
X-28.169
Y-17.272
X-27.711
Y-5.486
X-27.940
Y-17.018
G0 X-22.631 Y-4.928
G1 Y-4.750
X-24.105
Y-17.602
X-22.631
Y-5.004
X-23.851 F#505
Y-17.348
X-22.885
Y-5.258
X-23.597
Y-17.094
X-23.139
Y-5.512
X-23.368
Y-16.840
G0 X-18.085 Y-4.928
G1 Y-4.750
X-19.507
Y-17.653
X-18.085
Y-5.004
X-19.253 F#505
Y-17.399
X-18.339
Y-5.258
X-18.999
Y-17.145
X-18.593
Y-5.512
X-18.796
Y-16.891
G0 X-17.653 Y-6.985
G1 X-19.939
G0 X-22.225
G1 X-24.511
G0 X-26.797
G1 X-29.083
G0 X-29.235 Y-4.547
G1 X-27.178
X-27.889 Y-3.835
X-29.896
Y-3.658
X-28.727
Y-3.378
G0 X-29.235 Y-4.547
G1 X-30.175 Y-3.607
G0 X-28.727 Y-2.159
G1 Y-1.981
X-30.201
Y-3.429
X-28.727
Y-2.235
X-29.947
Y-3.175
X-28.981
Y-2.489
X-29.693
Y-2.921
X-29.235
Y-2.692
X-29.464
G0 X-30.099 Y-4.191
G1 X-27.051
G0 X-24.155 Y-2.134
G1 Y-1.956
X-25.629
Y-3.404
X-24.155
Y-2.210
X-25.375
Y-3.150
X-24.409
Y-2.464
X-25.121
Y-2.896
X-24.663
Y-2.667
X-24.892
G0 X-24.155 Y-3.378
G1 Y-3.632
X-25.324
X-25.146 Y-3.835
X-23.368
X-22.657 Y-4.547
X-24.663
X-25.603 Y-3.607
Y-3.531
G0 X-25.400 Y-4.191
G1 X-22.479
G0 X-19.583 Y-2.159
G1 Y-1.981
X-21.057
Y-3.454
X-19.583
Y-2.235
X-20.803
Y-3.200
X-19.837
Y-2.489
X-20.549
Y-2.946
X-20.091
Y-2.718
X-20.320
G0 X-19.660 Y-3.404
G1 Y-3.658
X-20.650
Y-3.835
X-18.796
X-18.085 Y-4.547
X-20.066
X-21.006 Y-3.607
G0 X-20.828 Y-4.191
G1 X-17.907
G0 X-15.240 Y-1.905
G1 Y-1.727
X-16.281
Y-3.581
X-15.240
Y-1.981
X-16.027
Y-3.327
X-15.494
Y-2.235
X-15.748
Y-3.073
G0 X-15.011 Y-3.835
G1 Y-1.549
G0 X-16.459
G1 Y-3.581
X-15.596 Y-4.445
X-13.513
Y-4.953
G0 Y-4.445
G1 X-14.122 Y-3.835
X-15.011
X-14.884 Y-3.912
X-16.002
G0 X-16.256 Y-4.191
G1 X-13.335
G0 X-10.465 Y-2.159
G1 Y-1.981
X-11.938
Y-3.429
X-10.465
Y-2.235
X-11.684
Y-3.175
X-10.719
Y-2.489
X-11.430
Y-2.921
X-10.973
Y-2.692
X-11.201
G0 X-10.541 Y-3.607
G1 X-11.532
X-11.557 Y-3.810
X-9.652
X-9.017 Y-4.445
X-11.024
X-11.862 Y-3.607
G0 X-11.684 Y-4.191
G1 X-8.763
G0 X-9.601 Y-4.039
G1 X-11.278 Y-4.013
G0 X-13.462 Y-2.159
G1 Y-1.651
G0 X-18.034
G1 Y-2.159
G0 X-22.606
G1 Y-1.651
G0 X-27.178
G1 Y-2.159
G0 X-31.750
G1 Y-1.651
G0 X-33.299 Y-2.184
G1 Y-2.007
X-34.773
Y-3.429
X-33.299
Y-2.261
X-34.519
Y-3.175
X-33.553
Y-2.515
X-34.265
Y-2.921
X-33.807
Y-2.718
X-34.036
G0 X-33.299 Y-3.505
G1 Y-3.632
X-34.646
X-34.722
Y-3.404
G0 Y-3.632
G1 X-33.807 Y-4.547
X-32.055
G0 X-31.801 Y-4.724
G1 X-32.461 Y-4.064
Y-3.835
X-34.519
G0 X-34.544 Y-4.191
G1 X-31.750
G0 X-36.322 Y-2.159
G1 Y-1.651
G0 X-38.125 Y-4.470
G1 X-39.345 Y-3.251
G0 X-40.005 Y-4.648
G1 Y-4.851
G0 X-37.440 Y-25.552
G1 Y-25.375
X-38.100
Y-40.488
X-37.440
Y-25.629 F#505
X-37.846
Y-40.234
X-37.694
Y-25.883
X-37.770
Y-39.980
G0 X-37.363 Y-40.310
G1 X-34.798
X-30.785
G0 X-30.886 Y-40.513
G1 X-37.109 Y-40.538
X-37.338 Y-29.159
Y-29.972
X-37.109 Y-30.709
X-36.703 Y-31.318
X-36.246 Y-31.928
X-35.839 Y-32.233
X-35.255 Y-32.588
Y-34.544
X-35.535 Y-34.798
X-35.890 Y-35.204
X-36.220 Y-35.662
X-36.373 Y-36.119
X-36.500 Y-36.855
Y-36.830
G3 X-31.064 Y-36.830 I-33.782 J-36.830
G1 X-31.166 Y-35.966
X-31.521 Y-35.306
X-32.004 Y-34.823
X-32.385 Y-34.519
Y-32.588
X-31.674 Y-32.283
X-31.191 Y-31.826
X-30.658 Y-31.242
X-30.328 Y-30.531
X-30.099 Y-29.845
X-30.048 Y-29.235
X-30.124 Y-29.312
G3 X-37.338 Y-29.312 I-33.731 J-29.312
G0 X-37.592
G2 X-29.870 Y-29.312 I-33.731 J-29.312
G0 X-29.616
G3 X-37.846 Y-29.312 I-33.731 J-29.312
G0 X-38.100
G2 X-29.362 Y-29.312 I-33.731 J-29.312
G0 X-29.947 Y-30.023
G1 X-29.972 Y-31.953
X-31.344 Y-32.588
X-31.725 Y-32.614
X-30.810 Y-32.004
X-30.226 Y-31.267
X-30.099 Y-30.937
X-30.429 Y-32.182
G0 X-30.531 Y-31.496
G1 X-29.947 Y-30.023
G1 X-32.055 Y-32.791
G0 X-32.182 Y-32.639
G1 X-32.156 Y-34.620
G0 X-30.048 Y-32.969
G1 Y-32.791
X-32.004
Y-34.595
X-30.048
Y-33.045
X-31.750
Y-34.341
X-30.302
Y-33.299
X-31.496
Y-34.087
X-30.556
Y-33.553
X-31.242
Y-33.833
X-30.810
Y-33.680
X-31.013
G0 X-30.023 Y-32.182
G1 Y-32.004
X-30.963
Y-32.588
X-30.023
Y-32.258
X-30.709
Y-32.334
X-30.277
Y-32.283
X-30.480
G0 X-29.896 Y-34.823
G1 X-31.852
G0 X-31.547 Y-34.569
G1 Y-35.154
G0 X-31.318 Y-35.306
G1 Y-34.874
G0 X-31.064 Y-34.976
G1 X-31.318 Y-35.433
G0 X-31.115 Y-35.865
G1 X-31.064 Y-34.976
G0 X-30.810 Y-36.830
G2 X-36.754 Y-36.830 I-33.782 J-36.830
G1 X-36.398 Y-35.357
X-35.662 Y-34.493
X-37.160 Y-34.519
X-36.957 Y-36.855
X-36.855 Y-34.646
X-35.916
X-36.779 Y-35.890
X-36.652 Y-34.798
X-36.017 Y-34.646
X-36.678 Y-35.357
G0 X-35.433 Y-32.918
G1 Y-32.741
X-37.211
Y-34.392
X-35.433
Y-32.995
X-36.957
Y-34.138
X-35.687
Y-33.249
X-36.703
Y-33.884
X-35.941
Y-33.503
X-36.449
Y-33.630
X-36.195
Y-33.553
X-36.322
G0 X-35.484 Y-32.791
G1 X-37.236 Y-31.013
X-37.033 Y-32.690
X-35.992 Y-32.461
X-37.084 Y-31.394
X-36.906 Y-32.588
X-36.347 Y-32.156
X-36.932 Y-31.674
X-36.652 Y-32.537
G0 X-37.008 Y-36.830
G3 X-30.556 Y-36.830 I-33.782 J-36.830
G0 X-30.302
G2 X-37.262 Y-36.830 I-33.782 J-36.830
G0 X-36.220 Y-38.786
G1 Y-38.608
X-37.033
Y-40.107
X-36.220
Y-38.862
X-36.779
Y-39.853
X-36.474
Y-39.116
X-36.627
Y-39.599
G0 X-35.331 Y-39.929
G1 Y-39.751
X-36.297
Y-40.107
X-35.331
Y-39.929
X-36.043
G0 X-30.988 Y-39.472
G1 Y-39.294
X-32.080
Y-40.107
X-30.988
Y-39.548
X-31.826
Y-39.853
X-31.242
Y-39.700
X-31.572
G0 Z[#801+5] (RETRACT UP)
G0 X-30.023 Y-26.619
G1 Y-25.527
G0 X-36.017 Y-25.679
G1 Y-25.502
X-37.338
Y-26.289
X-36.017
Y-25.756
X-37.084
Y-26.035
X-36.271
Y-25.883
X-36.830
G0 X-15.367 Y-6.985
G1 X-13.081
G0 X-10.795
G1 X-8.509
G0 X-6.223
G1 X-3.937
G0 X-2.413
G1 X-1.905
G0 X-1.778 Y-4.191
G1 X-2.413
G0 X-3.937
G1 X-7.239
G0 X-7.214 Y-3.708
G1 Y-3.327
G0 Y-3.708
G1 X-6.375 Y-4.547
X-5.969
G0 X-8.890 Y-2.159
G1 Y-1.651
G0 X-6.223 Y-15.367
G1 X-3.937
G0 X-2.413
G1 X-1.905
G0 X-2.032 Y-17.602
G1 X-2.286 Y-17.856
Y-19.482
X-1.041
Y-28.829
G0 X-0.483 Y-28.778
G1 X-2.515
G0 X-0.178 Y-18.974
G1 Y-40.335
G0 Z#800
M5 M9 (SPINDLE STOP)
(2.40mm ROUTER BIT <<--======)
M6 T2 (SET INSERTED BIT at Z0)
M3 S3600
G0 F#502(START OF DRILLING)
X-10.897 Y-31.750
X-10.897 Y-31.750
G1 Z#804 (Z DRILL)
G3 X-10.592 Y-31.750 I-10.744 J-31.750
G3 X-10.592 Y-31.750 I-10.897 J-31.750
G3 X-10.897 Y-31.750 I-10.744 J-31.750
G0 Z[#805+5] (RETRACT UP)
X-33.731 Y-29.312
G1 Z#804 (Z DRILL)
G3 X-33.426 Y-29.312 I-33.579 J-29.312
G3 X-33.426 Y-29.312 I-33.731 J-29.312
G3 X-33.731 Y-29.312 I-33.579 J-29.312
G0 Z#800
M6 T3 (SET INSERTED BIT at Z0)
M3 S3600
G0 Z[#800+5] (SAFE RAPID)
(2.40mm ENGRAVING CUTTER)
M6 T4 (INSERTED ENGRAVING CUTTER at Z0)
M3 S3600
G0 X-3.277 Y-22.758
G1 X-13.945
Y-22.962
X-3.277
Y-22.860
X-12.319
G0 X-5.664 Y-29.743
G1 Y-28.550
X-5.817
Y-35.560
X-5.664
Y-30.175
X-5.740
Y-33.934
G0 X-19.685 Y-37.338
G1 Y-36.144
X-29.845
Y-39.370
X-19.685
Y-37.744
X-28.219
G0 X-19.177 Y-28.092
G1 Y-26.899
X-28.778
Y-34.011
X-19.177 F#505
Y-28.524
X-27.153
Y-32.385
X-20.803
Y-30.150
X-25.527
Y-30.759
X-22.428
Y-30.455
X-23.978
G0 Z[#801+5] F#502 (RETRACT UP)
G0 X-38.964 Y-27.356
G1 Y-26.062
X-41.546
Y-39.522
X-38.964
Y-27.788
X-40.305
Y-37.897
G0 X-41.199 Y-15.164
G1 X-43.002
Y-16.332
X-41.199
Y-15.748
X-42.088
G0 Z#805 (RETRACT UP)
F#503
(==== GROOVE ROUTING ====)
G0 X-67 Y1.194
G1 Z#804 (Z ENGRAVE)
G1 X-7.518
G2 Y-7.518 X1.194 I-7.518 J-7.518
G1 Y-40.513
G2 X0.000 Y-41.707 I0.000 J-40.513
G1 X-42.049
G2 X-43.243 Y-40.513 I-42.049 J-40.513
G1 Y-25.298
G2 X-42.049 Y-24.105 I-42.049 J-25.298
G1 X-18.186
G1 Y-21.996
G1 X-50.165
G1 X-64.110 Y1.194
( 618 ITEMS FOUND )
(TRACK:--------------)
( 532 found )
( 532 engrave_found )
( 532 engraved )
( 0 rout_found )
( 0 routed )
( 0 , 0 dups.)
(FILL: --------------)
( 68 found )
( 63 engrave_found )
( 63 engraved )
( 5 rout_found )
( 5 routed )
(ARC: ---------------)
( 16 found )
( 16 engrave_found )
( 16 engraved )
( 0 rout_found )
( 0 routed )
(PAD: ---------------)
( 2 found )
( 0 drilled )
( 2 routed )
(SLOTS: -------------)
( 12 found )
( 12 routed )
( 0 , 0 missed)
( 4 TOOLS LOADED )
G0 Z#806
M30
(------- end -------)
Center click on this image for clearer display, or click then click again on big image.
Image compliments of NCPlot.com
