603,365 active members*
2,723 visitors online*
Results 1 to 4 of 4
    Mar 2014
    1141
    Automatic start/stop spindle on tool change?
    What is the best way to automatically stop the spindle on tool change and start when the user hits the Cycle Start button?
    Does Mach3 has the ability to achieve this or the does the user need to add M3 and M5 manually to g-code files?
    Mar 2003
    35494
    Re: Automatic start/stop spindle on tool change?
    You can have mach3 stop it, but you need an M3 in your g-code to start it. I put an M5 in the g-code to stop it as well.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2014
    1141
    Thanks Gerry.
    Better than nothing. Where do you set this option in Mach3?
    I think the post processor can be modified in order to have M3 and M5 in generated g-codes.
    Mar 2014
    1141
    Found it.
  1. Spindle won"t start after a Tool Change!?
    By Driller2 in forum SprutCAM
    Last Post: 10-31-2015, 07:25 AM
  2. Replies: 2
    Last Post: 01-04-2015, 03:51 AM
  3. Spindle start and stop and tool change
    By inman20k in forum BobCad-Cam
    Last Post: 09-15-2012, 10:35 PM
  4. NEW AUTOMATIC TOOL CHANGE CNC ROUTER SPINDLE, PRE-RELEASE
    By blurrycustoms in forum News Announcements
    Last Post: 11-09-2010, 11:16 PM
  5. Spindle stop prior to tool change?
    By nitemare in forum Mori Seiki Mills
    Last Post: 04-21-2009, 12:37 PM
