603,953 active members*
2,601 visitors online*
Results 1 to 5 of 5
    Nov 2009
    6
    autonomous cnc router
    Are there any plans or does the following even exist?
    I would like an autonomous cnc router that I can place on a surface and it is self-aware of its location and is self-contained.
    No table, no gantry, no rails. Just a self moving router that can adjust it's z-axis and move x and y on it's own.
    I guess it would need some sort of laser tracking to discover where it is and then follow it's instructions moving as necessary around the work piece.
    I can see this becoming an issue if it mills an area that is in its path of movement. Are there any products like this; what are they called?
    Zach
    Mar 2003
    35494
    Re: autonomous cnc router
    This is probably the closest you'll find.
    Handibot®
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2009
    6
    Wow, thank you. That was amazing. Years ago I bought an epilog zing 24 and did lots of cool craft stuff. But I always wanted to do shoji style panels. This tool is amazing. Thank you so much for pointing me in this direction.
    Apr 2004
    733
    https://printrbot.com/shop/printrbot-crawlbot/
    Uses belts that you place on the surface instead of rails.
    Apr 2007
    https://shapertools.com/
    this one looks pretty cool..it uses a vision system to orient itself to the program and workpiece
  1. Replies: 7
    Last Post: 10-13-2015, 07:28 PM
  2. Steel Router Mount for Milwaukee 5625 Router
    By sharbold in forum For Sale Only
    Last Post: 06-22-2015, 09:47 PM
  3. Mini cnc router Wood cnc router Sinomac S8- mini hoby cnc router 0609
    By Winni-Sinomac06 in forum Commercial CNC Wood Routers
    Last Post: 04-14-2015, 03:07 AM
  4. Autonomous Xylotex
    By Sanghera in forum Xylotex
    Last Post: 04-29-2007, 02:52 PM
