My Z axis drops when the motors are disabled. I'm using Clearpath motors on an AVID Z stage with a 22 pound 3 kw Water cooled spindle so I imagine that's the reason its an issue for me and not a bigger one for more people.
When motor is enabled or running there is no problem at all, but if i screw up and fault them, which I often do as I learn to use this, or simply when I shut it down for the day, the Z drops and I have to re-zero and/or the weight of the assembly drives the bit into the material.
I have seen springs on some DIY kits so I must not be alone. I have also seen a vid where someone put a brake on the zaxis motor but I don't think he was completely satisfied with that solutions release/engage timing.
I have an air cylinder I was going to fit to provide an air spring counterbalance but before going to that complexity I need to ask if anyone has solved this more simply.
