603,855 active members*
4,145 visitors online*
Results 1 to 5 of 5
    Apr 2009
    60
    Axis calibration
    Hi guys
    I've just finished my small router, it uses 1mm pitch thread lead screws and anti backlash nuts. At the moment the motors are set at 2000 steps, 200 steps per rev, micro stepping x 10 so we should have 2000 steps per mm travel, correct? Trouble is even though both X and Y axis run the same motors and srews there seams to be a small amount of difference in distance traveled. Is it ok to set sets different for each axis or should I look else where? So more steps = less distance covered, correct?
    Jun 2010
    4260
    That is wrong.
    Try halving the acceleration and top speed, and see what happens.
    Cheers
    Apr 2009
    60
    If I half the speed I'll have to reduce the cutter RPM by half as well, right? I don't think my dremel will have any power that slow...
    So you think I may be loosing steps?
    Dave
    Jun 2010
    4260
    TRY!
    Quote Originally Posted by 4lowie View Post
    You don't have to reduce the speed of the Dremel just to run some tests.
    That's my first guess.
    First find out what is happening ...
    Cheers
    Apr 2009
    60
    I'm using the Gecko 540.
  1. Axis calibration
    By 4lowie in forum Community Club House
    Last Post: 12-19-2011, 09:48 AM
  2. X and Y axis Calibration?
    By onlyjus in forum DIY CNC Router Table Machines
    Last Post: 08-01-2011, 05:09 AM
  3. Axis Calibration
    By davidshearer in forum Tree
    Last Post: 03-10-2010, 04:47 PM
  4. calibration of x and y axis
    By japco43 in forum Calibration / Measurement
    Last Post: 01-26-2010, 11:12 PM
  5. x and y axis calibration
    By japco43 in forum DNC Problems and Solutions
    Last Post: 04-27-2009, 08:07 PM
