603,795 active members*
3,529 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Axis disable in fanuc 31i- madel A5
    May 2012
    Post Axis disable in fanuc 31i- madel A5
    Hai
    I need to disable W and B axis while doing some machining operation is under progress,
    Let me know the procedure to axis disable and enabling in fanuc 31i model A5
    Thank
    SRIMURTHY
    Jul 2010
    118
    do W and B axis have a clamp code ?
    any axis with a clamp code is automaticaly disabled during clamping.
    naturally the mechanic's need to exist and be electrically controlable(at least detectable), then
    pmc changes is requiered for an axis without clamping function prepared beforehand, best to consult the MTB 1st.
  1. 4th axis disable/enable
    By davesnd in forum Fanuc
    Last Post: 07-04-2023, 08:38 AM
  2. How to disable the Windows on Fanuc 160is
    By Namnp2007 in forum Fanuc
    Last Post: 12-01-2022, 12:17 PM
  3. Fanuc OTT C Axis Disable - URGENT HELP PLEASE
    By BryCAM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2011, 06:15 PM
  4. Fanuc 16i-M 4th axis disable
    By MDR32 in forum Fanuc
    Last Post: 07-23-2010, 01:07 PM
  5. Mach3 Z-axis disable when not in use
    By Erant in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-18-2008, 12:52 PM
