603,380 active members*
3,555 visitors online*
    Aug 2007
    7
    Axis Movement
    I am running Camsoft Pro. When I cycle start my program I have a U axis that starts to move and then my program will start like it is suppose to. Why would my U axis do any moving if the program I am running doesn't tell it to do anything?
    Mar 2004
    1527
    You'll likely need the Pro's at Camsoft for this one. More investigation is needed. Add the command LOGOPEN SILENT to your startup.fil. Save Logfile.fil before after and during the problem. This file contains every command that has been processed. Its a bit hard to follow, after six years of working with Camsoft I still rely on Rubin and Ernie<Camsoft Techs> to help me figure it out.
    Karl
  1. New SX3 - Axis Movement
    By meyermicro in forum Syil Products
    Last Post: 05-27-2008, 02:36 PM
  2. No Z-Axis Movement
    By btcoutermash in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2007, 08:42 PM
  3. Axis movement is not smooth
    By bgolash in forum Stepper Motors / Drives
    Last Post: 12-19-2005, 10:36 AM
  4. Axis Movement
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2004, 08:33 PM
  5. 4th axis movement (and a few other gen ?s)
    By corpse in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2004, 12:13 AM
