588,169 active members*
4,383 visitors online*
Thread: Axis Removal
    Oct 2009
    47
    Question Axis Removal
    We have 7 Axis hooked up to a 8055M. One of the never used axis servos is dead, so not the "Reference All" won't work any more. The dead axis is one that has not been used since we got the machine, so we just want to disable / remove it, atleast for the time being.
    What do I need to do to eliminate it so when the operator hits "Reference All" it will complete without any errors?
    Thanks in advance for any assistance!
    Motion Master 5 Axis Router.......Fagor 8055/C.......Surfcam Velocity 4.0 B189
    Dec 2011
    73
    Quote Originally Posted by Stupidav View Post
    You have to modify the general parameters.
    On the general parameters screen you have all the axis listed (P0-P7) and each one had a value that represents the axis name. Which ever axis you wish to no longer use, simply change that corresponding axis to 0 and then reset the control (press shift and then reset) and you should no longer see that axis.
    The installation manual has all the lists of which port relates to which parameter and what number is what label/name for the axis.
    http://fagorautomation.com/pub/doc/F..._8055_inst.pdf
  1. Z axis servo removal... help! Please
    By badboy_matt in forum Fadal
    Last Post: 07-12-2011, 04:17 AM
  2. Okuma Z-Axis Motor Removal.
    By RileyBRoo1 in forum Okuma
    Last Post: 06-18-2010, 11:29 PM
  3. VMC 15 z axis servo removal
    By cncpilot in forum Fadal
    Last Post: 01-19-2010, 04:50 PM
  4. Fanuc OMD 4th Axis Removal Problem
    By drgbt in forum Fanuc
    Last Post: 02-12-2009, 08:34 PM
  5. 4th axis removal
    By fokusco in forum Haas Mills
    Last Post: 06-10-2008, 11:53 PM
