603,838 active members*
3,098 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Axis travel (physically measured) doesn't match Mach3
Results 1 to 7 of 7
    Mar 2008
    33
    I have a Zenbot 2424 CNC Router, about 6 months old. I haven't used it much lately, after sitting for about a month, now I'm having an exasperating problem:
    If I jog the X axis 10" across the table (I placed marks on the table and aimed for those), the Mach 3 readout only shows about 9.375"
    If I try and move only 2.25", the readout shows about 2.125, so it seems to multiply as the distance moved increases.
    Anyone have any suggestions? I can only think to re-install Mach3 or get the manufacturer to send me a new control box.
    Feb 2009
    6028
    Think in diagnostic? Anyway, you just tell it how far to move, then put in the actual movement amount.
    Feb 2009
    48
    go to the setings tab bottom left corner set steps per unit
    Jan 2011
    49
    should the Z axis dip switches be set as the X,Y ? Because right now I am running my machine 1/2 steps, I asked around and some say 1/8 steps but it just moves so darn slow. What shall I do?
    Thank you
    Jan 2011
    49
    stepping
    One thing I forgot to add is that I am useing 10-2 3/8 acme lead screwws on all axis
    Oct 2011
    Hello
    i think your problem is adjust and set the distance in the axis ,you have to :
    1- open your mach3 ,
    2-click on settings Alt6
    3-click on "Set steps per Unit"
    4-A window will appear and ask you to put a number of the distance in inchs,for exemple put 10 ,and click on OK.
    5-the axis will move and it stop you should Measures the distance ,for exemple you will find 9.39 inch ,a window will appear and you write this value .
    finally the program will give you the caluculated steps and the velocity and acceleration,
    your axis will move with the new values so you can get a exact distance from your G code
    Jul 2007
    1602
    This video shows what the previous poster was explaining.
    [ame=http://www.youtube.com/watch?v=XkO5tc-jSxw]Improved Mach 3 Axis Calibration - YouTube[/ame]
    bob
  1. d and h offsets with measured tools
    By Magpie73 in forum Fanuc
    Last Post: 05-25-2012, 02:06 PM
  2. How to physically move the mill?
    By FloridaClay in forum Shopmaster/Shoptask
    Last Post: 07-04-2011, 10:34 PM
  3. the same physically?
    By Claude Boudreau in forum Stepper Motors / Drives
    Last Post: 03-26-2010, 12:12 PM
  4. adding 4th axis: need to match existing servo?
    By BiggerHammer in forum CNC Machine Related Electronics
    Last Post: 01-14-2010, 01:35 AM
  5. Travel Compensation in mach3
    By altered in forum Mach Software (ArtSoft software)
    Last Post: 01-10-2009, 04:43 PM
