603,310 active members*
2,961 visitors online*
Results 1 to 5 of 5
    May 2023
    8
    AXYZ 4008 Router
    I have a AXYZ 4008 ATC CNC Router which requires a major service. During an audit we found the linear bearings grease nipples are not easily accessible and to remove the linear bearings is a big exercise. I require the all the linear bearing part numbers.
    If anyone could be kind to assist with any technical information regarding servicing of the machine and supply me with a BOM (Build of material) we would greatly appreciate it.
    Dec 2003
    1344
    Re: AXYZ 4008 Router
    AXYZ will supply a very slim nozzle that fits a standard grease gun.It isn't particularly cheap,but it makes the job quite easy.
    May 2023
    8
    Hi Routalot
    Thank you for the info. I'm based in Mauritius and have mailed AXYZ but haven't had any response.
    I also require the linear bearing part numbers as accessibility to the mounting bolts is a challenge as there needs to be somewhat to dismantle to reach the bolts.
    Thx
    Dec 2003
    1344
    Have you tried the UK branch of AXYZ?They will be several time zones closer,which helps with the overlap of the working day.These pages may be of interest to you:
    https://uk.cncshop.com/collections/a...ew=bc-original
    https://uk.cncshop.com/collections/a...32399948415060
    Oct 2024
    6
    Since you're seeking a BOM and specific part numbers, contacting AXYZ directly would be a good option. They should be able to provide technical manuals or the BOM that includes part numbers for the linear bearings. If you have the original machine manual, it may list the part numbers for the linear bearings and other components. If you don’t have access to it, AXYZ's customer support can usually provide a copy.
    Oct 2024
    6
    Contacting AXYZ directly is a solid step to obtain the build of materials (BOM) and the specific part numbers for the Crossed Roller bearings. Manufacturers often have detailed technical manuals or customer support teams that can provide this information.
    If the user has the original machine manual, it could indeed contain the necessary part numbers and service guidelines. However, in cases where it's unavailable, AXYZ's customer support is likely the best resource to obtain the correct documentation or even guidance on servicing the machine. This will ensure the parts are accurate and the service process is done correctly.
