588,585 active members*
13,540 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jan 2005
    15362
    Re: AXYZ 4008 Spindle not starting
    Quote Originally Posted by CPH1 View Post
    Thanks for your reply. I have done those checks on the tool release and it all works fine. I have all the manuals, tool changer and vacuum bed .
    Today I managed to get it to run the F function to start the spindle manually and it started up the cooling fan and it made the spindle have some resistance when turning it by hand (Normally the spindle has no resistance). However the spindle still did not start turning.
    The Fault code could be a wiring problem, did you wire this or was it done in the factory, Don't keep trying it until you check the wiring it could be missing a Phase
    What is your input power supply
    Mactec54
  2. #22
    I realise this is an old post but it appeared on a Google search for me and I believe I may have a soluton for anyone with the same problem. check the 2 compressed air lines aren't around the wrong way on the spindle inputs leading to the spindle being continuously locked when compressed air is connected or disconnected and expelling air when air is connected. spindle lock would cause that error code.
Page 2 of 2 12
  1. Replies: 0
    Last Post: 01-26-2019, 06:12 AM
  2. AXYZ 4008 ATC
    By egallegos in forum Commercial CNC Wood Routers
    Last Post: 08-15-2018, 08:22 AM
  3. USED AXYZ 4008 - What to do with it ? help welcomed!
    By JinMTVT in forum DIY CNC Router Table Machines
    Last Post: 02-09-2015, 02:00 PM
  4. AXYZ 4008 CNC Router !!!
    By kawman in forum BobCad-Cam
    Last Post: 08-01-2013, 01:26 AM
  5. Axyz Automation 4008
    By Fran_k in forum Commercial CNC Wood Routers
    Last Post: 10-07-2010, 07:22 PM
