549,832 active members*
2,251 visitors online*
    AXYZ router cutting error
    I uploaded a picture to show what I am experiencing.
    When my CNC is cutting, it will shudder a little bit (most times, not all), and all of a sudden it's out of alignment. It is cutting .5" to the left of where it should be. This is happening in the X and the Y direction.
    I have already contacted AXYZ tech support, but tech support told us we are running too fast (@75IPM). They recommended slowing it down. That doesn’t seem to make sense.
    Help!
    Thanks,
    Jon
    Shaw124
    Guest
    Re: AXYZ router cutting error
    AXYZ router cutting error, Need correction if i am doing any mistake, Is there anybody who can solvepaper writing services issue and help me to find error and after that help me to solve this error. Hope the whole you understand and now ready for my help because it is necessary for me.
    Aug 2021
    A new router cutting error has been discovered by an expert in the industry. This error can cause your machine to malfunction and may be costly for https://budgiebasics.com/how-to-crea...budgie-easily/. To prevent this, we recommend that you check with your supplier if they have updated their firmware version to fix these problems.
  1. Replies: 2
    Last Post: 01-08-2018, 01:25 AM
  2. AXYZ router pauses when cutting an arc
    By beeman_mccheyne in forum Uncategorised WoodWorking Machines
    Last Post: 01-21-2014, 03:40 PM
  3. Axyz router cutting UHMW
    By dbrnmllr in forum Glass, Plastic and Stone
    Last Post: 01-24-2012, 08:53 PM
  4. 3D Cutting with Artcam Express and AXYZ Router
    By CNCRam in forum ArtCam Pro
    Last Post: 05-06-2011, 09:49 AM
