603,943 active members*
4,135 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > B Axis Control for 2000SY
    Mar 2008
    34
    Hello all,
    I would like to drill two holes of different diameters (.187" and .339") simultaneously on a Puma 2000SY using the Fanuc B axis control function. I would like to have a drill facing east and the other west on the same turret station. I would like to drill a hole on the main spindle using the turret in the Z minus direction, while the B axis sub spindle is feeding onto the drill facing the Z plus direction at twice the feed rate (or whatever ratio necessary). Has anyone ever attempted this successfully on a Doosan SY lathe, and would they be willing to post an example program here?
    Thank you.
    May 2007
    16
    Hand code:
    1 the turret down to position
    2 move the B to posittion
    3 feed into main spindal
    4 feed out of main spindal
    5 feed into sub spindal
    6 feed out of sub spindal
    7 repeat 3 to 6 as a pseudo peck
  1. Puma 2000SY - gibbs mdd file needed
    By ShortRunCNC in forum Daewoo/Doosan
    Last Post: 08-18-2008, 11:41 PM
  2. edgecam post puma 2000sy
    By riverking in forum Daewoo/Doosan
    Last Post: 08-18-2008, 10:02 AM
  3. Can you control axis through macro?
    By jaredp in forum Mach Software (ArtSoft software)
    Last Post: 02-09-2007, 01:08 AM
  4. How to control 8 axis?
    By lepton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-20-2006, 03:35 AM
