603,942 active members*
4,317 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > B-axis limit on Fadal
    Sep 2006
    83
    We have a 1992 Fadal 6030 with the Numatix CNC retrofit. The problem I am having is that the B-axis will only rotate 21 deg. one way and 28 deg. the other way. Is there a way to change this setting on the axis card for more swing? I am thinking that this a Fadal upgrade that will cost mucho dollars. I was hoping the Numatix retrofit would change it but it still uses the Fadal control cards.
    Thanks in advance.
    Mar 2003
    900
    The axis eproms control the limits of the movement for the axes. The standard eproms allow a G90 movement of B+15 and B-265 degrees. A total sweep of 110 degrees.
    Neal
  1. 4th Axis for Fadal 4020
    By Fudd in forum Fadal
    Last Post: 07-23-2012, 09:49 PM
  2. Fadal 4th Axis Rotary /w Thru Hole ?
    By northwestfab in forum Fadal
    Last Post: 12-15-2007, 04:16 AM
  3. B-axis limit on Fadal
    By 5th-axis in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-06-2007, 04:35 PM
  4. Haas 4th axis on a Fadal ???
    By Greg Mueller in forum Fadal
    Last Post: 06-16-2007, 09:51 AM
  5. Fadal VMC4020A axis problem
    By cwww in forum DNC Problems and Solutions
    Last Post: 12-02-2003, 06:07 AM
