587,178 active members*
4,630 visitors online*
IndustryArena Forum > CAM Software > UG NX > Back cutting a radius
    Feb 2009
    5
    I'm having difficulty trying to back cut a blend radius and was wondering if anyone can give me some advice on what strategy to use?
    We are using NX 7.5.
    The component has a bore straight through of 60mm and an outside dia of 100mm. It has a stub going in through the OD with a bore of 40mm with a blend radius of 2.5mm with the 60mm bore.
    I am trying to use a T-Cutter of 25mm dia x 4mm.
    I understand I can never physically cut the correct radius profile all around but the more I can machine on the better.
    Currently my only mehtod is to chop the component in half and machine it backwards in NX, then invert the Z axis movements manually. A mistake is bound to happen with this method!
    Hopefully one of you out there can point me in the right direction for this sort of cutting, in my mind it should be simple but NX seems to struggle, highly frustrating!
    Any help is much appreciated.
    Cheers.
    Sep 2009
    78
    Re: Back cutting a radius
    Can you post images of the part so we know exactly what you're trying to accomplish?
    NX 10.0.3
  1. cutting radius on okuma lathe
    By clayd-cnc in forum Okuma
    Last Post: 11-04-2010, 11:48 AM
  2. Plasma table steps out and back on a radius?
    By slamabus in forum Mach Plasma / Laser
    Last Post: 12-28-2009, 05:48 AM
  3. cutting curves, circle, radius?
    By _taz_ in forum Benchtop Machines
    Last Post: 02-08-2008, 06:57 PM
  4. Problem with radius cutting?
    By jamesigi in forum CNC Wire Foam Cutter Machines
    Last Post: 06-13-2007, 10:32 PM
  5. cutting a radius
    By kazam07 in forum MetalWork Discussion
    Last Post: 05-26-2007, 03:06 AM
