I have an Okuma Lathe with OSP700L Control. What is the best way to go about backing up the parameters? I assume that there is a way to copy them to the floppy?
the best way is to go into edit aux and do a data pip to an osp formated disk. this will make an A.top file on the disk. if the machine has a B turret you will need to do this 2 times, the second time (And second disk) you will designate B.top.
Intialize two floppy disks which you will use as follows.
1st disk : used for storing part program data and A.TOP file generated from the data PIP function.
2nd disk : Used for storing *.PBU file parameter data.
-Insert a new unformatted disk into the floppy disk drive.
-Press EDIT AUX mode key.
-Press the EXTEND function key (F8) once.
-Press the INIT function key (F2), the CRT will display:
=IN
-Type in "FD0:" press WRITE key, CRT will display:
intialize OK (Y/N) !
***IMPORTANT***
IF NOTHING IS TYPED IN AND THE WRITE KEY IS PRESSED THE MEMORY FOR THE PART PROGRAMS WILL BE ERASED BECAUSE MD1: IS THE DEFAULT!!!!
-Type "Y" and press WRITE key, the CRT will display:
format (2DD-720K=0,2HD-1.44 M=1)!
-Type in a "1" or "0" depending on the type of diskette you have and press the WRITE key.
When the equal (=) sign appears, formatting is completed. This disk is now OSP formatted.
BACKING UP PARAMETERS ON LATHES
1. Go into PARAMETER mode and put the control in METRIC mode by changing NC Optional Parameter Bit #3 bit 0 to a 0.
2. Go into EDIT/AUX mode and press F3 to access the PIP function. Press the COPY function key and key in MD1:*.*,FD0: and then press the WRITE key.
3. After cursor returns and the light turns off on the disk drive, press F7 to quit the PIP function. Press F8 (extend) two times until you see F5 (data PIP) function key.
3A. Press the F5 funtion key to enter the DATA PIP function. Press the F2 (output) key and key in FD0: and press the WRITE key. At the ! prompt, press the WRITE key again. This will create the A.TOP file which will be sent out to the floppy disk. When the cursor (>) reapprears at the bottom of the screen, the procedure is finished.
***IMPORTANT***
On lathes with two turrets, it is best to make two seperate parameter backup files, one for the upper turret and the other for the lower turret. This can be done by keying in FD0:UP.TOP;A in step 3A above. Keying in FD0:LOW.TOP;B will create the parameter backup file for the lower turret. The filename can be up to 8 characters long and the file extension has to be TOP. the ;A and ;B are what tells the control to create a parameter backup file for only the upper or lower data.
it's also possible to write parameters to MD1: and copy that to MSDOS format floppy after. Parameter file is just simple text - it's editable.
Transfer to PC via RS232 is best.
DPIP>, then "out", ten just <enter> for all parameters.
I advise many kinds of copies in CD,floppy and HD keeping
Set the following parameters on the machine:
Optional Parameter bit Value
#1 00011011
#8 10101010
#12 10100010
Optional Parameter word Value
#1 0
#39 9600
#54 1
To set the CNC up for drip feed:
Drip feed on this control is an optional extra, see the Okuma manual for instructions.
Set ConnectCNC as follows:
Common Settings
Name Okuma 7000
Baudrate 9600
Data bits 7
Stop bits 2
Parity Even
Flow control Xon/Xoff
Xon Char. 17
Xoff char. 19
Port as available
Each file should begin with filename.MIN without the
How do you delete the protected .PBU files? I've went through the unprotect ;C procedure, and it errors out. They are eating up all the memory!
Thanks,
GP
Cause that's part of the system software.
I see the parameter back-up files in there. I agree they are they system files. I need to explain more.
1. They had a problem with the machine.
2. They restored the software
3. Now I can only carry a couple programs, like the memory is less, or the .pbu's are hogging up all the space.
4. I clicked the free soft key & it is full with two "small" programs (it's a lathe).
You must have Floppy-D for back-up and restore parameters.
what memory size in kilobytes?
what size these two part programs are?
I tried this today on OSP7000. it works well.
To write the file to MD1:......
DPIP
OUTPUT
MD1:
when asked for output data type press [WRITE]
all parameters, offsets, user data etc is saved to file MD1:A.TOP
For twin turret....
If A turret offset/data is needed type MD1:A.TOP;A
If B turret offset/data is needed type MD1:B.TOP;B
In MSDOS mode press COPY, type MD1:A.TOP,FD0:
to copy file to floppy
File is just text sure, but to understand what the numbers mean its necessary to read operator manual pages which details what is what because it's a big mess of numbers that are not easy to understand without the manual
Try FREE;C this will show you the continuous free space.
Try DIR;P this will show files with protection levels.
PBU files should only be in MD0: as with all system files. MD1: is for program storage. Sometimes MD0 is used for additional program storage since memory is small.
If you are working with MD1: and FREE;C shows much smaller continuous space, COPY *.*,MD1: will reorganize files to be defragmented.
Experience is what you get just after you needed it.
Wiz.... that is an 8 year old thread
Only go back to VECKTs post...
