603,953 active members*
3,740 visitors online*
Results 1 to 7 of 7
    May 2012
    BACKING UP PROGRAMS SINUMERIK 840D
    has anyone backed up parameters and programs from the 840d on to a flash drive via the front or behind the screen ports?
    May 2012
    36
    I would also like to know this
    Message sent using the htc EVO with Tapatalk......2
    Oct 2007
    53
    RS-232 on Sinumerik 840 D
    I have done RS-232 communication on many Sinumerik Controls, but at one customer I find Error while opening the COM Port of CNC. There is no mistake in the procedure I follow. Is there anything in system which enables COM port of Sinumerik 840-D ?
    There are 2 machines here, with same problem. As soon as I select a MPF file to send to PC, I get an Error on CNC as Job Terminated. If I see the log, it says Error in opening COM
    May 2012
    36
    Menu select
    Servers
    Data out
    Select file to copy to flash drive
    Disk/card
    Tab to Arch format: Punch tape CR+LF
    Start
    Will copy to your flash drive.
    Sent from my Nexus 7 using Tapatalk 2
    May 2012
    36
    Make sure it's same com port # on 840D as on the pc
    Oct 2007
    53
    Smile Thanks
    Quote Originally Posted by gunrights View Post
    Thx for your help.
    The problem was in BIOS set up. Simens Engineer had to boot the system with PC key board. He then saved COM-1 port, with IRQ4. Then it worked well.
    May 2012
    36
    Quote Originally Posted by Digitech View Post
    Thx for your help.
    WOW....that brings back memories. Always seem to forget that the Siemens control is just a PC. But we don't normally deal with com ports much anymore on the PC side. Most computers no longer even have a com port. But that reminds me I do have a com port to USB adapter that I could use on some of our older machines that do not have flash drive support.
    Just come back couple days ago from Chiron America where we are passing off for new mails with 840D. Then by February we will have a total of 10 of them passed off. They are coming in for it a time. Hope they don't make changes in the control between each set.
  1. Need Help - Sinumerik 840D system
    By M.RISHIKESH in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-01-2023, 08:35 PM
  2. Sinumerik 840C, Sinumerik 840D
    By marek-vavra in forum SIEMENS -> Sinumerik 840C
    Last Post: 09-02-2022, 07:04 PM
  3. Sinumerik 840D
    Last Post: 05-24-2012, 03:14 PM
  4. Sinumerik 840D Measuring Cycles
    By IfeCro in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 03-25-2012, 02:58 PM
  5. Sinumerik 840D Powerline Parameters-Help me
    Last Post: 03-14-2012, 10:40 AM
