Originally Posted by
RCaffin
Hi Louie
(My bolding) Fortunately, the primary assumption here is wrong. What we might generally call 'friction' has two components, which we may term 'dynamic friction' and 'static friction'. The latter is more commonly known as 'stiction'.
Dynamic friction is basically the shearing forces between the two surfaces at the microscopic level. There are two components to this. The first is the straight mechanical deformation which happens during shear - a bit like shearing gear teeth off with too much torque. The other part is due to what we call 'Van der Walls' forces. These happen at the atomic level: surface atoms on one side actually making chemical bonds with surface atoms on the other side. The whole area constitutes a majort part of a rather hairy subject known as 'Tribophysics'. Anyhow, it takes energy to break these bonds once they have been made.
Stiction is a special case of the above, when the macro forces are not sufficient to break the Van der Waals forces. Under these conditions there is no movement between the two surfaces. This is what a friction drive aims for.
So what's with the need for high contact pressure? The higher the pressure, the more of the tiny lumps and bumps on each surface are flattened down, so that the contact area rises. The more contact area, the more Van der Waals forces available.
Incidentally, these same Van der Waals forces are what lets a gecko walk across a ceiling upside down. Great stuff! And, I suspect, part of the reason soft aluminium sticks to some cutters. The right lubrication aims to keep the surfaces apart - one molcule diameter is enough.
Bottom line: if the torque levels are not too high, there may be no slip at all in a well-designed friction drive.
Cheers
Roger
