603,336 active members*
4,036 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Backup files on OSP5000LG
Results 1 to 4 of 4
    Mar 2010
    9
    Hello,
    I have an old LB-15 lathe with the OSP5000-LG control. I would like to backup the IGF files in the control to disk. Can anyone give me some tips on how to do this? Thanks.
    Dave
    Jun 2015
    4189
    Re: Backup files on OSP5000LG
    this is it ? omg nice ... it has no inputs ? usb ? floppy disk ?
    does it have a hdd ? if yes, take it out and put it in another pc and copy all
    can you connect to that hdd inside ?
    Apr 2009
    1273
    The 5000L-G was using Bubble memory at the time and has no hard disk. The only way to save the IGF file is to do it on an Okuma formatted floppy. Floppy drives were not standard on the machine at that time, so you would need to have one in order to accomplish this. The IGF file has an expanded ASCII character set, so it will not transfer over RS-232.
    Best regards,
    Experience is what you get just after you needed it.
    Dec 2008
    3211
    Quote Originally Posted by Dave2962 View Post
    Hello,
    Dave
    This control can do a DIR (Directory listing) but it has a default setting of *.MIN filenames.... so it won't show all files
    * is a wildcard combination of any characters
    ? is a wildcard character
    if you go <EDIT> <DIR> *.* <WRITE>
    - it should give you a listing of ALL files contained in the control memory
    I think you can batch transfer, but it needs to be written correctly
    ie <EDIT> <PIP> CO MD1:*.MIN FD0; ( this would copy all min files onto an Okuma formatted disk )
    Similar method exists if you have the MSDOS option on the control
  1. num 1040 backup files
    By ahsameh in forum DNC Problems and Solutions
    Last Post: 12-18-2014, 04:19 PM
  2. Backup System and Files
    By cncadmin in forum Autodesk
    Last Post: 10-19-2013, 01:30 AM
  3. What files do I need to backup
    By Jwl in forum Fanuc
    Last Post: 11-24-2012, 02:06 AM
  4. Backup ALL files to floppy
    By DEAN in forum Haas Lathes
    Last Post: 12-22-2011, 12:29 AM
  5. Need Backup files for Emcoturn 340
    By rocketcheese in forum DNC Problems and Solutions
    Last Post: 03-27-2011, 03:44 AM
