603,783 active members*
2,596 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Feb 2007
    126
    Re: Ball in a cage example
    Where did you find the model? The problem with this is that it has a set cut path which it steps down in Z to cut each face. It does the whole path, steps down and does it again. You cut a lot of air and each face took me 30-45 minutes.
    If I could get a model I could program it to rough and finish and not cut air as much. I've not made any since the first. It was neat as heck but just took too long.
  2. #22
    Dec 2004
    783
    The model is really easy to draw, did one from Baltic birch ply years ago, left the ball attached to the bottom though.
  3. #23
    Nov 2007
    2151
    wow
    Just found this wanting to learn more about parametric programming
    Like others have mentioned above it took about 10 minutes to design this.
    I use cam software and different types of operations on each of the six sides. that took a bit more time
    Was fun and I also did a couple variants.
    Attachment 245010
    osage orange, mahogany and acrylic.
    Clip of cam screen
    Attachment 245012
    no parametric programming in these. Just started learning these techniques.
    md
  4. #24
    Feb 2007
    126
    Say, could you attach the graphics file? What CAM system did you use? I can do pretty basic stuff in MasterCam.
  5. #25
    Nov 2007
    2151
    I used sprut
    I guess I don't know how to attach a model iges file.
    Can anyone advise what method attachment, link or what?
    md
Page 2 of 2 12
  1. Centurion 6 Card Cage Mess
    By bwilkinson in forum Milltronics
    Last Post: 03-04-2014, 04:09 PM
  2. Need to build a small aluminum cage
    By bobk544 in forum Welding Brazing Soldering Sealing
    Last Post: 08-22-2011, 05:00 PM
  3. KM3P Card Cage bottom wires
    By kc8jyr in forum HURCO
    Last Post: 07-08-2011, 02:14 PM
  4. KM3P Card Cage wires
    By winds1sj in forum HURCO
    Last Post: 07-06-2011, 02:48 AM
