588,189 active members*
4,081 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Ball nut arbor size for 1605 ball screw
    Apr 2003
    302
    Does anyone know what the arbor size (id and od) for a ball nut off of a 1605 ball screw?
    Kevin
    Re: Ball nut arbor size for 1605 ball screw
    Our SFSR / SFIR/SFHR 1605 ID: 15mm OD:28mm SFNUR 1605 ID: 16mm OD:28mm
  1. Ball screw size/pitch?
    By jakk100 in forum DIY CNC Router Table Machines
    Last Post: 01-09-2016, 04:41 PM
  2. EZPATH S ball screw size
    By mmckell in forum Bridgeport / Romi Lathes
    Last Post: 10-27-2011, 05:36 PM
  3. What size ball screw ???
    By milldrillmaniac in forum Linear and Rotary Motion
    Last Post: 02-03-2009, 10:16 PM
  4. Ball screw and Stepper Motor Size
    By ericdwilso in forum Linear and Rotary Motion
    Last Post: 05-21-2007, 08:40 PM
  5. Machining the ends of ballscrews & ball screw size
    By Zumba in forum Linear and Rotary Motion
    Last Post: 02-15-2006, 05:47 PM
