Hello All,
I tore down a previously converted machine I bought to clean it up and ended up replacing one ball screw nut on the Y axis. Screw is a 16mm x5mm lead. When installing the nut things did not go well and a few balls were displaced. I looked online and found a few videos on how to reball a nut. I decided to just remove it completely and then reinstall all the balls. that went well but the leadnut is crazy sloppy. I ended up adding a few more balls form the replacement to get to 17 in each track and its still loose. I checked the Ball diameter and both the new ball nut and old have .124" diameter balls. I only have calipers, but they are good ones and both sets of balls measure the same. This seems odd and I wonder if I did anything wrong. The balls must be in the correct tracks otherwise it would lock up after a few turns. The orange ball returns seem sloppy too, I can pinch them and get the screw tighter, but the whole thing sounds like a skateboard bearing form the 70's. Also as I pinch each one, I can feel the balls going through and one of them feels very lumpy as if something is wrong in that track Does .124" size balls seem right base don others who have replaced balls before. I am thinking i should order new larger ones from McMaster but unsure just what to buy. I am open to any help or suggestions.
Best regards,
Marc
