567,250 active members*
4,341 visitors online*
IndustryArena Forum > General Maintenance > BallScrew Repair > Ball supply and other questions
    Dec 2019
    10
    Hi, Trying to re-ball a TBI double nut 32x5mm pitch screw with 260 nominally 1/8" balls while keeping costs down. There was play and some fine metal particles so I pulled it down. The screw and nut look OK under a magnifier, as do the balls. However I wanted to install new balls as the machine is old and there must be some wear. I noted on a previous post a ball supplier Bal-Tec. They seem excellent. They are not dirt cheap because (1) I'd have to guess and buy a range of ball sizes, and (2) they seem to use UPS which to Australia is not cheap for a handful of balls.
    As per this previous post here (and the Bal-Tec website) there are indeed two sizes of balls in my screw approx 1 thou difference in size (that'll be fun re-balling).
    I've got few questions;
    1. Is there other quality ball suppliers?
    2. I assume one would ideally like the nuts to be close to a preload condition when reassembled without nut preload?? Is that correct?
    3. Is there a way to get some idea of the wear e.g. Reassemble the old system without preload and feel?? Try and measure (indicate) radial movement, not easy and some complex geometry in the
    ball contact to come up with a new ball size.
    4. The other method which is obviously used is trail and error (probably the best method) but what sizes to try given the costs of buying many ball sets. Try + 1, 2 & 3 thou?? Does someone have
    some experience and could help with a 0better guess
    Re: Ball supply and other questions
    hi,
    die kugeln brauchen eine sehr hohe präzision und solltest du in der 1 µm abstufung haben. wir haben hier ein riessiges sortiment.
    doch ich empfehle es dir uns zu schicken und wir bringen den kugelgewindetrieb wieder auf die richtige vorspannung. wir überprüfen das am drehmoment prüfstand.
    jürgen
  1. ball screw questions
    By mechhamo in forum Linear and Rotary Motion
    Last Post: 09-10-2020, 11:43 PM
  2. where supply TBI 2005 ball screw.
    By Longzhichuang in forum DIY CNC Router Table Machines
    Last Post: 06-28-2019, 10:43 AM
  3. Ball/Leadscrew questions:
    By Dave's_Not_Here in forum Linear and Rotary Motion
    Last Post: 05-15-2005, 03:16 AM
