588,268 active members*
9,306 visitors online*
    May 2005
    674
    Ballnut wipers
    Are you using ballnut wipers on woodworking machines? If so, where did you get them and how much did you pay?
    May 2005
    674
    Nobody's using wipers? I don't know whether to rejoice at my potential cost savings or be a bit alarmed at the thought of potential bearing failures...
    Aug 2003
    494
    Hi Zumba,
    I'm not using wipers because I bought the cheap ballscrews but I am thinking of having a greased leather strap/thonging hanging over the groove with a lead weight on it so it tracks with the screw to wipe the gunk off before it gets in the ball nut. I used to use these on my pushbike years ago to keep the axle clean and they last for years on a smooth surface. Not the best solution but it's a start with 2 either side of the nut.
    The Neuron.
    I am not completely useless.......I can always serve as a BAD example.
