588,616 active members*
6,180 visitors online*
    Oct 2011
    Ballscrew replacement..
    I've got to replace the ballscrews on an old Miyano BNC34T, I've never done this before so its going to be quite the little project full of a lot of learning..
    I've gotten a quote on the new ballscrews from Miyano, which I know come with just the screw and the nut.. Thing is, I KNOW there are going to be other pieces that need replacing, but we don't want to get into it and then have to sit and wait a few weeks to find other parts we deem need replacing as we open it up..
    When replacing ballscrews, generally, what other items would you replace at the same time?
    Thanks..
    Feb 2009
    6028
    Thrust bearings and any support bearings. Lube metering units. Have proper sized lube line on hand.
    Feb 2009
    6028
    Oh, and axis belts if it has them.
  1. Ballscrew Cover Replacement on TM-1
    By heavensoutlaw in forum Haas Mills
    Last Post: 10-24-2022, 09:25 PM
  2. X axis ballscrew replacement
    By gamila in forum Fadal
    Last Post: 06-06-2015, 12:00 AM
  3. Shizuko AN-S X Axis Ballscrew Replacement
    By GTRClive in forum Linear and Rotary Motion
    Last Post: 02-01-2010, 07:34 PM
  4. Ballscrew replacement/regrind?
    By jetblackaircraf in forum Linear and Rotary Motion
    Last Post: 05-01-2009, 11:26 PM
  5. EZ-Trak DX2 Z ballscrew replacement
    By brassdrift in forum Bridgeport / Hardinge Mills
    Last Post: 01-19-2008, 01:35 AM
