603,311 active members*
4,108 visitors online*
Results 1 to 7 of 7
    Jul 2006
    1256
    Ballscrew whip
    Being researching ballscrew Whip it all evening and came to the conclusion DEVO was into ballscrews.Here are some lyrics:
    When a problem comes along you must whip it
    Now whip it - into shape
    Shape it up, get straight
    Go forward, move ahead
    Try to detect it - it's not too late
    To whip it, whip it good
    How does one calculate ballscrew whip?
    I saw a 5X10 Thermwood with at least 2" screws and there was a lot of whip like a skipping rope.Is this hard on the ballnuts and end support bearings?
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Oct 2003
    530
    you sure it's not bent!
    Mar 2003
    35494
    Quote Originally Posted by lgalla View Post
    Go to www.nookind.com and use their critical speed chart.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2006
    6
    Ballscrew whip
    Many moons ago I saw a crane with a 15m long screw drive. The crane was about 100 years old. It had supports that held the screw at the correct height and eliminated whipping. It consisted of two 1/2 nuts mounted on backets that alowed the crane to move over the supports. As it passed, it knocked the one half nut down which in turn raised the second half nut. Somebody with CAD should make us a proper drawing as it should be a common solution looking for a problem.
    Jul 2006
    1256
    Update,
    I called the guy with the router for more info.He was just showing off with 1000ipm rapids.The machine has something similar to what Jan described.Spring loaded plastic supports which swing out of the way as the ballscrew passes.The screws are near 11 feet long to accommodate the tool changer.Conclusion,If you expect high rapids on over 10ft you will need huge screws and probably a machine weight over 10,000lbs to tolerate the forces generated.
    Driven nut looks good to me.
    Larry
    Aug 2004
    421
    We have a machine with 12' travel and 1500 ipm travels. The reason the screw doesn't whip is because it is stationary, the nut turns. It is also 3 to 4 inches in diameter.
    If you try to make everything idiot proof, someone will just breed a better idiot!
    Aug 2007
    147
    Komo routers are in the 2000 ipm range for moving gantry routers, and 3000 ipm for moving table routers. They use helical R&P.
  1. lead screw whip ? bearing to use and why?
    By technomage in forum Linear and Rotary Motion
    Last Post: 05-08-2007, 12:16 AM
  2. ballscrew whip
    By planescott in forum Mechanical Calculations/Engineering Design
    Last Post: 03-24-2007, 12:13 PM
  3. leadscrew whip ?
    By tomcat47 in forum Linear and Rotary Motion
    Last Post: 02-14-2007, 04:06 PM
  4. Shaft Whip
    By thielert in forum DIY CNC Router Table Machines
    Last Post: 03-29-2006, 06:29 PM
  5. Lead screw whip
    By spalm in forum DIY CNC Router Table Machines
    Last Post: 05-24-2005, 08:04 PM
