I have a 10 inch band saw that has quite a high FPM and i would like to slow it down a little to be able to cut aluminium. i though about re-gearing it which would be possiable take alot of work. is it possiable to just put a rotary switch on the power like the x2 mill? (different switch but that idea) would that be possiable or would it stress the motor to much i know when you cut the power it reduces the the amount of power the motor produces......
thanks guys
Mike
