587,149 active members*
5,019 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Baruffaldi turret Type : DMS-08BF -FANUC
    Jun 2021
    6
    I use this drive model Baruffaldi turret Type : DMS-08BF
    I recently had a problem and the error 9.2 is displayed on the drive
    Please advise how to fix this error
    Do you have the list of alarms, please give me
    Best Regards
    [email protected]
    Dec 2012
    395
    Re: Baruffaldi turret Type : DMS-08BF -FANUC
    Just visit the Baruffaldi website and scroll down to the bottom: https://www.baruffaldi.it/en/manual/
    You can contact them because you need a login for download.
    I have a pdf for the newer DB21 - drive, but the pdf for the one you have is also for download.
    This is what my DB21-drive pdf says:
    9.2 Zero search in operative mode different from 1 - Code 29
    The alarm is activated after the START command, before unlocking the turret when:
    - Operation Mode (=)> 2
    - Position code = 0
    - Check code management of the position in the plc.
    - Check wiring of connector J1
    Jun 2021
    6
    HI Men
    Thank you very J1 connector completely, there is no problem.
    Do I have to look for problems in the device controller software (FANUC Series OI-TD)?
    Is it possible that the drive is defective?
    What does this mean?
    - Position code = 0
    To solve ((((this issue - Check code management of the position in the plc))).
    Which part of the controller should I refer to?
    Is there a way to ignore(BY PASS) this error or must the problem be solved?
