603,781 active members*
2,822 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Basic Machining/Milling books/resources?
Results 1 to 4 of 4
    Oct 2003
    57
    Hello, i was curious if anyone knew of any books that outlined the basics of machining/milling? I would take a class at the local college but i just don't have the time. I have access to a 3 axis cnc mill that can also be run manually. I am just looking for basic information on the different types of cutters, hold-downs, vises etc and what applications they can be used in, and the different milling techniques. Information on how to calculate feed rate for cutting different types of materials and at what depth each pass can be cut at as well. If anyone knows of any resources be it a book or online that can help me out i would greatly appreciate it! Thank you all in advance.
    Mar 2003
    507
    There's a book titled "The amateur's lathe" by Lawrence H Sparey. Published by Model & Allied Publications, Argus Books Limited, Argus House, St James Rd, Watford, Herts.
    It's an old book (last print 1976) but worthwhile to read.....
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
    Oct 2003
    263
    Software For Metalworking
    http://closetolerancesoftware.com
    Jul 2004
    79
    I recently purchased a book titled "Turret Mill Operation" by John G. Edwards. I covers the very basics of operating a typical Bridgeport style knee mill. It discusses different types of attachments and cutters that are often used as well as the basic operation of these mills. It's a very good book for beginners.
  1. newbie Quest. Basic Static Load on Linear Bearing Block kNewton ?
    By Calico in forum Linear and Rotary Motion
    Last Post: 06-28-2007, 12:10 AM
  2. Extremely basic machining question.
    By touser in forum MetalWork Discussion
    Last Post: 06-19-2005, 06:51 AM
  3. basic machining question
    By senor J. in forum MetalWork Discussion
    Last Post: 12-08-2004, 05:48 AM
  4. Hs Cnc & Basic Eletronics
    By stanfield in forum Community Club House
    Last Post: 04-29-2004, 10:37 PM
  5. Basic DOS CAD and CAM programs
    By JFettig in forum Uncategorised CAM Discussion
    Last Post: 03-06-2004, 05:43 AM
