587,682 active members*
3,409 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Basic mechanical engineering questions for new build
Results 1 to 19 of 19
    Aug 2010
    Hi guys,
    I've been lurking around in this fine forum for a couple of months.
    When I'm not reading this forum, I usually spend a lot of time building guitars.
    And that's what I'd like to build a DIY CNC router for. - The goal is to be capable of routing wood (anything form low to high density) and certain metals such as brass and aluminium with precise enough for guitar necks, bodies and hardware.
    Work space should be around 140x80x20cm...
    I'm good with electronics, software, cad, and planning BUT I have only very little experience in mechanical construction using metals.
    Also I'm not sure if/how I can provide the necessary precision for working with metal.
    What tools do you deem necessary for building such a CNC?
    How do manage to work accurate enough (e.g. when drilling an endless series of holes for screwing rails)?
    Does it make sense financially, to "outsource" the mechanical part to more skilled/better equipped people?
    Thanks for any hints!
    -Tom
    Jan 2005
    15362
    schoeftinger
    Yes it does make sence sometimes
    If you want to build a precise & accurate well built machine, & you don't have the machines to do it, then it would be better to outsource that part of the build
    If you draw up the parts you need made, get prices, from your local shops,when the parts are made, inspect the work/parts they have made for you, to make sure it is all to you drawing/spec
    Take a look at my build this may give you some idea's as well http://www.cnczone.com/forums/cnc_wo...ld_friend.html
    Mactec54
    Aug 2008
    1166
    Instead of outsourcing custom designed parts, most people buy components that are already designed and available such as bearings and blocks from cncrouterparts.com. Or if you want higher grade stuff, you can buy bearing blocks, ball screws and linear bearings on ebay from Chinese vendors such as linearmotionbearings2008 and others. This lowers your cost as the setup costs are spread over a much larger number of people.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Aug 2010
    Well, thanks for the infos!
    I got a decent drill press (a heavy one) and a lot of hand tools.
    Most of my electric tools were made for wood-working.
    However, I don't think I have the capability of precisely cutting metal.
    The thing, I have most respect for is to build a gantry from solid 2cm Aluminium and drilling 20 holes over a distance of 100cm dead straight in line for screwing the Y-axis rails to it...
    I've been asking around at local hardware and machine builders/companies.
    Their prices are exorbitant...
    My estimation is around 2000 EUR just for cutting, sizing, and drilling the parts...
    -Tom
    Mar 2003
    35538
    By clamping a fence to your drill press table, and clamping the work to the fence, it's relatively easy to get all your holes in a straight line.
    Aluminum can be cut with most woodworking tools. Miter saws, and table saws with sliding cut off tables have no problems cutting extrusions and smaller plates.
    Larger pieces can be rough cut with a jigsaw, and the edges cleaned up with a router and straightedge.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    You can achieve some pretty good precision just with a fine scribe, files, and punches. It has worked for hundreds of years. With experience building guitars, you have more than sufficient skills to work with metal. Just a few minor differences in the tools and the cutting speed.
    There are good reasons for screws not to be in perfect alignment anyway. Holes in a straight line is a method used to *weaken* materials. That is how perforations make things break off at a pre-determined place. Staggered holes are pretty standard for structural drilling for most things.
    Some of the drilling matters, much doesn't. It only matters that the holes align for the fastener. Just clamp things together and drill them at the same time. Many things are slotted or drilled oversize instead of just a single straight hole to allow movement for alignment.
    Generally, the basic tools for cold working metal are: a square, a scribe, some dividers, calipers and a good rule for measuring, a drill with an assortment of drill bits, a set of files, a hammer, and saws for sawing straight and for curves. It's not that complicated.
    My uncensored views and CNC Router planning: http://reinventingcnc.blogspot.com/
    Aug 2010
    Thanks again, for encouraging me!
    Yes - building a guitar requires some accuracy, but I guess precision is even more crucial when building a CNC router.
    I guess I'll never find out unless I try building one!
    This cries for a build thread...
    Do you have any recommendations on where to get materials (heavy Alu profiles, Alu plates) at decent prices in Europe?
    Thanks,
    -Tom
    No idea about stuff in Europe. I am down in the southernmost part of Texas in the US.
    If your goal is to cut metal as well, you might as well think about doing steel structure instead of aluminum. A good place to start would be to find places that do repairs of car exhausts and other welding. Many of those places might have people that are available to do some small tasks in their spare time between jobs. Take plenty of beer with you. That usually helps
    Aug 2010
    Quote Originally Posted by dkirtley View Post
    Material - good topic!
    I'd build the bottom frame/table from alu profiles - preferably heavy ones.
    I'm open to any input on the gantry material.
    The only limitation is that I can find rails and wagons (e.g. SBC Profilschienen) at a decent price which are able to carry the gantry.
    I figured aluminium would be a good choice because it's light.
    Using something heaver, such as steel, would require stronger steppers or a smaller thread pitch, IMO.
    However, I assume that heavier means less vibrations and - ultimately - more precision, right?
    Regarding the booze:
    If I take lots of beer with me, there's usually little left for the others.
    cheers,
    -Tom
    Mass on the stuff that doesn't move is your friend.
    Mass on the gantry is your enemy.
    If you are going to be cutting metal, you want a solid and distributed support. Each time the cutter comes in contact with metal, it acts much like a hammer blow. If it is too malleable (soft and bending when hit with a hammer) it will deform if the force is not distributed over an area so that the force is below the strength that will move the metal. Aluminum is usable for some stuff but for strength and wear resistance, steel is much better. Just a bit different to cut. You can build strong and light things from heavy materials. You can build heavy crap with light materials. They all have their good points and weaknesses. As an example, look at bicycle frames. You can have a strong light frame from steel, aluminum, titanium, or carbon fiber. Even wood.
    It doesn't only have to be just thick rectangular tubings and angle iron. There are many structural shapes available. Take an afternoon and go talk to a welder. They will know what is available in your area. They might even have left over pieces that meet your needs. A lot of this stuff comes in large sections and they end up having to buy a 7m piece when they only need 4m as an example. They would much rather get their money back selling it than having to store it and watch it rust. I again really advise going to a place that does auto exhausts and mufflers. That is where I have seen people with some of the best welding skills. They constantly deal with intricate stuff. Places that work on trailers and garage doors are also good sources. Also, don't overlook the places that make things with sheet metal. Many shapes that would otherwise cost a lot of money can be bent quickly with sheet metal tools.
    I realize that this is awfully vague but from half a world away it is hard to get specific.
    Aug 2010
    I get that idea, but wouldn't it be good if the gantry had a certain minimum mass in order to avoid vibrations?
    I'd use alu profiles (e.g. http://62.75.219.46/mod_show_image.p....jpg&width=270) for the cutting table because they come with flutes and matching nuts.
    This should simplify srewing the y-axis rails to them.
    So far, I couldn't find any similar profile systems from steel!?
    I'm still not sure on the gantry material.
    Some commercial CNCs I've seen are using 12mm aluminimum (cut from sheets) for the gantry.
    If I went steel, how thick would the gantry material have to be?
    I'll start asking around as soon as I have a concrete plan which materials to use.
    Right now, you got me thinking about steel vs. aluminium... :drowning:
    Ha - good one!
    Thanks!
    -Tom
    There will be plenty of mass just with the required structure. For the most part, adding mass only changes the frequency of the vibrations. You stop vibrations by not moving.
    My own personal opinion is that that those types of extrusions are not rigid enough for supporting the workpiece for cutting metal by themselves. I wouldn't be happy with it for cutting wood. Some people build with them and are happy. We all work to our own tolerances.
    I think you are too worried about the difficulty of drilling holes.
    Much of the gantry could easily be built rigidly with sheet in the range of 1mm - 2mm if supported properly in steel or aluminum without getting fancy with the design. Car bodies are made with thinner material. You just need some structure to bolt the rails onto.
    Aug 2008
    1166
    Adding mass only change the frequency of vibrations in theory. In reality adding mass can also add damping which will change the amplitude of any vibrations.
    I'd agree that extrusions are not stiff enough for high quality machining of aluminum as normally used, although many people here do okay with it (myself included). Typically you can't cut very fast or deep and surface finish is not the best. However 1-2mm steel is not going to be any better unless you use quite a lot of bracing.
    Aug 2010
    So you propose using a frame built from rectangular steel profiles - heavy table, light gantry?
    True that!
    If I learned anything when working on guitars, it's the fact that doing things repeatedly with high precision is VERY hard.
    From my experience, automotive plates are not that stable. - In younger years I've occasionally put some body weight on the engine cover... don't ask why!
    So it would be better to use thicker steel for the gantry sides and thinner material for the gantry bar (plus some steel/alu to reinforce whereever I need to drill the dreaded holes)...
    Quote Originally Posted by jsheerin View Post
    Bracing is always better but at the upper end of this range, 2mm steel is 14 gauge steel. This is thicker than most of the structural members that they use for the beams in steel buildings. They have off the shelf C-Channels that are 6 x 1-1/2 that are more than strong and rigid enough for this type of application. They are easy to get sized up to 12" x 3-1/2".
    You have to consider the cross sectional area. It's not just the metal thickness.
    Aug 2008
    1166
    It's the polar moment of inertia. Personally I just simulate it with FEA. It's too complex to do much by hand on structures like these. My current router measures and models to have a stiffness around 2000 lbf/in using ~3mm wall steel tubes with 3"x6" cross sections (which is roughly equivalent to the 80/20 extrusions I used - those are too complex to mesh in FEA). To cut aluminum with reasonable quality, from my research you'd want to be in the 20,000-80,000 lbf/in range. To cut steel, more like 60k-140k. Mori Seiki specifies their standard milling machines are 228k and their high precision machines ~650k.
    I doubt commercial buildings are anywhere near that stiff, but I have no experience with that so that's just a guess. I know the floors in my last house were not that stiff - I could feel them bounce slightly under my weight.
  17. #17
    Yes, those are gorgeous machines but I really don't have that much faith in engineering data that goes that far beyond what is usable. It is pretty much salesmanship on their part. The machines may be that rigid but unless the workpiece is cast integrally in the bed, it is overkill. The clamping devices are nowhere near that rigid. The milling cutters are nowhere near that rigid. The positioning system is nowhere near that rigid. Any of those three things move and it doesn't make one bit of difference how rigid rest of the machine is.
    Yes, your floor might have been less than perfectly rigid but a CNC router table gantry won't have many hundreds or even thousands of pounds of preloaded weight with a couple hundred pounds of live load bouncing around on top of that in the middle of a 20' span. With enough load, anything will either move or break.
    But anyway, the topic here is CNC router tables and specialized metal cutting machines costing $100K+ goes way beyond anything that anyone could expect from their performance. It doesn't take anywhere near that much rigidity to hold a router spinning a small milling cutter taking a light cut on aluminum or brass.
  18. #18
    Aug 2008
    1166
    If this is all you want, then aluminum extrusions as typically used are fine. If you want a higher quality cut in aluminum, then you need something stiffer. I cut aluminum all the time with my router. It works, but it's slow and the surface finish isn't that good - I can feel the cutter marks easily when my router stops and changes directions. If the frame was stiffer, this would happen less.
    Your statement seems to be a popular opinion around here - "I don't trust calculations". If it didn't make a performance difference, machine tool builders wouldn't spend money and time on it. Marketing wouldn't matter - they would just market that their machine was cheaper (due to less material used) and still produced great quality of cuts (which they would then demonstrate on the machine). Then they could sell their machines for less money and sell more of them. The extreme example of a mill I gave is for achieving tolerances in the sub 1um range (0.00004") while cutting steel. So yes, that's not needed for a router. But if your primary use of a machine is to cut aluminum and it's in the 4'x4'x6" travel range, you need something stiffer than what is typically done with aluminum extrusions or 2-3mm steel beams of the same outer dimensions to get good cut quality.
  19. #19
    No, its not that I don't trust calculations, quite the opposite actually. I just have seen a lot of glossy sales brochures that are, shall we say, overly optimistic.
    The whole selling more machines at a lower price concept is pretty alien in the CNC world. They probably will never get adopted in high enough volume to take advantage of real mass production. There is no real reason that a tabletop CNC router should cost more than say $500 if they were being mass produced.
    Just out of curiosity, have you tried the purpose made aluminum router bits? Specifically, I am talking about the single flute endmills. I have thought about picking one up to try but the only machine I have available to play with right now has the original 6mm collet and a 1/8" that I had to make for it.
  1. Mechanical Engineering Bachelor online?
    By diyengineer in forum Want To Buy...Need help!
    Last Post: 01-24-2011, 02:56 AM
  2. Machinist getting a Mechanical Engineering degree.
    By Burns in forum Community Club House
    Last Post: 01-31-2010, 05:23 PM
  3. some really basic X3 build questions
    By BiggerHammer in forum Benchtop Machines
    Last Post: 12-21-2009, 07:29 PM
  4. mechanical engineering self study.....help
    By yousif_1985 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-04-2008, 08:06 AM
  5. Mechanical Engineering Internship in Vancouver, WA
    By damae in forum Employment Opportunity
    Last Post: 06-12-2006, 09:11 PM
