I'm a small operation so I can watch over any cutting done by the machine.
What is the simplest/cheapest THC controller out there?
I've got a Primeweld Plasma cutter with CNC outputs.
Thanks in advance!!
Thanks in advance!!
Is a sentance fragment?
We are using this one, see if it is suitable for you or not?
https://paycnc.com/torchheightcontro...620_p6680.html
Linuxcnc, QTplasmac config, mesa THCAD and Mesa 7i96s will give you a high performance plasma controller that will blitz any external THC for < $200
Linuxcnc does not use a traditional THC. Instead it does the torch height internally. It uses a Mesa THCAD to read torch voltage. It is a high performance voltage to frequency converter. The frequency is sent to an encoder input on the 7i96s and its converted to a voltage in software where high performance PID routines keep the torch height constant under control of the motion planner. Because the motion planner knows everythuing thts going on it does a better job.
Rod Webster
www.vehiclemods.net.au
I ordered a cut60 on Black Friday so just started looking into a THC myself. This is just a hobby machine for me and trying to balance the cost vs performance tradeoffs...... so I'm curious if you got one installed and what you think of it. I also ordered a tig325x to upgrade my 225x so trying to stay more towards the cost side of the equation without going too cheap. Thanks.
I think it's important to know what you're getting, especially when it comes to CBD products. Misleading labeling can be frustrating, and transparency about CBD content is crucial.
I've recently stumbled upon something called HHC Gummies that seems to be gaining attention in the wellness community. Before you consider trying them out, it might be a good idea to check out the post about what is HHC Gummies.
As for those Butterfly Gummies, it's disappointing when products don't provide clear information about their CBD content.
Checkout this one:
https://cnc4pc.com/thc-2-plasma-torc...t-control.html
Arturo Duncan
https://cnc4pc.com
Naturopathic medicine offers a holistic approach to health care, focusing on the body’s natural ability to heal itself. As a naturopathic doctor in Michigan, we prioritize treating the root causes of health issues, whether it’s thyroid imbalances, autoimmune disorders, or gut health problems. By using safe, natural treatments, we support your body’s innate healing processes while minimizing harm. Our goal is to empower you with knowledge about your health, ensuring you’re an active participant in your wellness journey. With personalized care, we help you achieve optimal health and vitality naturally.
